Hi All, I was not able to search a hit for this and I don't see this mentioned much in the write-ups so far. What products, advice and/or processes do you use for removing swirls or scratches for the side mirrors? I was thinking plastx, plexus or similar plastic protection products but wanted to see what others do to de-swirl those side mirrors. Thanks for your help.
bumping since no responses yet. Any advice on how to remove swirls from side mirrors? Thnx for your help.
I treat side mirrors as I would painted plastic areas like front and rear bumpers. I use a 3 inch or 4 inch pad with a DA for side mirrors. In terms of type of pad and polish start from least aggresive and work your way up. Keep in mind the amount of heat you are generating. In most cases Menzerna IP and PF clean up side mirrors very well. Hope this helps. Cheers, Nick
