Removing rubber from burn outs
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by yamabob, Apr 7, 2012.
  1. yamabob
    yamabob Two Bucket System Washer
    Not sure if this is the right section,if not I apologize.
    A couple runs at the track have left some rubber from the tires stuck behind the wheels on the paint. Any ideas on the best solution? It's on there pretty good.
  2. chemgys99
    chemgys99 DB Forum Supporter
    Tarminator and plastic razor blade.
  3. Chaseme
    Chaseme DB Forum Supporter
  4. Obsessive Detail
    Another vote for Tarminator and plastic razor blade. I've used that method quite a bit and always works great.
  5. VW 91
    VW 91 Any Rag Vehicle Washer
    Depending on how long its been there, you could get away with just Tarminator by itself. I had burnt rubber on the lower rocker panels on my car for over 2 years that I was too lazy to clean up until I sprayed Tarminator on it and it just melted the rubber away. Just a swipe with a towel after 5 min and it was gone.
  6. Kaban
    Kaban Welcome to Detailing
    Where can you buy plastic razor blades locally OTC? Would a place like Home Depot have some for cheap?
  7. bryansbestwax
    Detailing supply, the bulk chemical type or a janitorial supply place. A few online stores carry them, like detail king or rightlook.
  8. chemgys99
    Yeah sometimes hard to get. It wouldn't be a bad idea for Phil to carry them.
  9. VW 91
  10. Chaseme
    Phil does have them. Under the Über line.
  11. yamabob
    Thanks guys!Tarminator it is. Next time I might Pam the area first
  12. HeavyD
    HeavyD DB Forum Supporter
  13. yamabob
    Awesome! Ready to tear it up now. Where are all them Vettes hiding
