Remove window writing?
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by sweetlou, Mar 23, 2009.
  1. sweetlou
    sweetlou Two Bucket System Washer
    I was wondering what the best way to remove that writing stuff (some kind of paint?) used to tag windows. I was thinking some kind of glass cleaner, or maybe an apc mix, what have people found to work best?
  2. mb43
    mb43 Obsessive Detailer
    Glass cleaner wouldn't cut it. Diluted APC should do the trick or even car shampoo. 2c.
  3. sweetlou
    do you think 4:1 is safe enough, b/c i already have that made
  4. 911Fanatic
    Try glass cleaner and 0000 steel wool.
  5. sweetlou
    Don't have steel wool with me, I'm just wondering if 4-1 apc is safeon windows?
  6. Jay J
    Jay J Birth of a Detailer
    APC would clean it..Don't use it on Sclass/LS/other coated winshields though
  7. dublifecrisis
    dublifecrisis Any Rag Vehicle Washer
    I've done full strength purple power and 10:1 Simple green and they both worked.
  8. richy
    APC and/or clay.
  9. TexasTB
    TexasTB Obsessive Detailer
    Exactly what I would recommend.
  10. 911Fanatic
    +1. Clay usually works quite well on glass.
  11. Detail Company
    Detail Company Any Rag Vehicle Washer
    Hi,
    use 1z Acrysol, is the best! :thumb:
    Best regards.
  12. TheJag
    TheJag Birth of a Detailer
    RAZOR BLADE! i've had to remove lots of that crap, and nothing works as good as a razor blade. make sure you do that before you wash the whole car though, because the residue that comes off is a pain if yoy already washed the car
  13. merlin3008
    merlin3008 Birth of a Detailer
    I'd use steel wool or razors as a last resort. Start with clay. It takes most stuff right off like a giant pencil eraser. next try an APC, just be careful not to let it run onto to paint take off the LSP.
  14. Buddy
    I've had good luck with 1Z Glass polish and The Makita...NICE...:thumb:
  15. Detail Company
    You must tray the 1Z acrysol, one friend off mine (he is in this Forum) he removed all the publicity of is brother car, and is the best!!!
    Trayet and tellme your feedback :thumb:.
    Best regards.
  16. magnumrt
    magnumrt Birth of a Detailer
    if its grease pencil writing try some IPA it also works to remove ink from fabric
  17. DC5Berry
    DC5Berry Any Rag Vehicle Washer
    Magic Eraser would probably work. Only a couple dollars at Walmart
  18. SpecC
    SpecC Wax on..Wax off
    clay takes quite a bit of effort, so i'd just recommend some APC
  19. Hum-Benz
    Hum-Benz Wax on..Wax off
    Acrysol and a fresh blade.
  20. mb43
    I have used APC on S class windshield. What is the danger of this?
