Rejex and PB wheel sealant
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by Misha, Feb 11, 2010.
  1. Misha
    Misha Nuba Guru
    would it be good idea to top rejex with pb or other way around?
    maybe putting couple coats of each on wheels?
    is there cure time for each?
  2. agpatel
    agpatel OD On Detailing
    Rejex I think is 12 hr cure time. Could do Rejex then top with PB.
  3. supercharged
    why not just do 2 coats of either one on it's own, and test durability???
  4. Misha
    Misha Nuba Guru
    ^^ i guess i can do it. put pb on one side of car and rejex on other side. would it be worth it to put 845 on half of the wheel? lol
  5. Denzil
    How is the RejeX stuff anyway? Is it any good?
  6. Misha
    Misha Nuba Guru
    Dave is using it so must be good.
  7. pektel
    pektel DB Forum Supporter
    I really like DG 501/105/AW combo on wheels. Looks killer.
  8. vtec92civic
    vtec92civic Nuba Guru
    I use Rehex as well . . . . works great. It has shown me some great durability.
  9. Denzil
    Cool, can't wait to hear his thoughts.
  10. supercharged
    test the two of your choice side by side on front wheels...
  11. Misha
    Misha Nuba Guru
    would it be good idea to devide wheel into like 5 parts(since i have 5spoke wheels, and put different sealants on it and see which one will do better job? or just do 2
  12. agpatel
    Just do left side and right side. That way you get better comparison. If you only do 2 spokes you dont have enough "area" to really test it out. Left side Rejax, right side PB. Rejex is great on wheels, not so good on paint because it really does not add too much to the looks but nice on wheels.
  13. Misha
    Misha Nuba Guru
    gona try to go outside and put it on one rear wheel since its cleanest. and wait till rejex comes to do rest
  14. Misha
    Misha Nuba Guru
    here is finished product. need to put another layer on top tomorrow
    this is what wheel looked like before. any way to get rid of it? tried wheel brightner and didnt help. looksl ike corrosion kinda
  15. billyblooshoes
    its just baked on brake dust. if straight wheel brightener wont do the trick, some wheel acid will for sure.
  16. agpatel
    I thought WB was wheel acid...if it is not then what is wheel acid, ha.
  17. Misha
    Misha Nuba Guru
    ok ill try strait up, too bad it doesnt cling, ill try with tooth brush or something
  18. slanguage
    I use CL-68 life long sealant on wheels, sometimes topped with 1Z spray wax, and I only have to clean my wheels with soap and water :D
  19. Misha
    Misha Nuba Guru
    i put PB selant on them. gona put rejex on it. and probably 845
