Another road trip up to Anderson, SC. Approx 170 miles each way. I left the house at 5am. I did not take alot of pics on this trip as I wanted to get both vehicles done in one day and avoid the $80 for a hotel. This time to do exterior details on a Camry and SRX, both red. Clients where able to secure me a garage to work in. First up is the camry w/ 22k miles. Its been sitting outside 24/7 as the clients are building a new house. They hope to be into the new house in a month or so, then I will go back up to polish his 07 Tundra. I arrived at 7:30am and got started at 8am on the camry. I foamed it down with CGCWC/Z7 combo and the lance. Scrubbed down the tires/wells/wheels with AM red hot APC. Rinsed everything off and refoamed to do a 2 bucket wash with Z7. Started out by trying to clay with the zaino clay and Z6 as a lube, but not on this contaminant ridden surface. Tar spots and sap everywhere. I moved up to a clay magic medium claybar and this is what it looked like after the trunk: After claying I have it a quick rewash, dried it and moved inside. For 22k miles it had a good amount of swirls. I made 3-4 passes with M105 and a yellow wool edge pad at 1700. Wanting to stay as efficent as possbile and with the lack of sun outside to check for holograms, I followed with ZPC/white CCS/PC6. This way there would be no need for a rewash prior to apply zaino. After a Z6 wipedown, I then applied 3x of Z2pro and followed with an application of Z8. I applied Z-16 to the tires and ZAIO to the wheels. While I was detailing the SRX the sun peaked out for a bit so I got a few quick shots: Caddy SRX w/ 40k miles. This one sits out 24/7 as well. Foamed the paint and cleaned the wells/wheels/tires the same as the Camry. This one also had some tar spots on the hood so I used the medium clay there and the zaino clay on the vert panels. I polished the hood with 3-4 passes of M105/yellow wool/1700. Before: After: Looks like this is a tinted clear: I then followed with ZPC/white CCS/PC6. On the vertical panels, I want to try out something a little different. So on the white CCS pad, I applied one thin 3" strip of M105 and two 3" thin strips of ZPC. I worked this at 1700 with the flex 3403 rotary. This combo worked very well and removed about 80-85% of the defects. Leaving only some deeper RIDS. I could not catch the sun outside to check for holograms, so to be safe I finished with ZPC/white CCS/PC6. After a Z6 wipedown, I applied 2x of Z5pro followed by Z8. Tires got Z-16 after the pics. By 7pm I was back on the road and home at 9:30pm.
Many apologies if this is a commonly asked question. I get all of your acronyms except "PC6". What is this? Fantastic job by the way. Can't say I've ever seen a tinted clear.
Excellent work, wow! I hope you charged for putting all those miles on your car. I personally charge close to 50c a mile here in Texas. Mindflux: Porter Cable on speed 6...
That's what I was thinking, but I didn't want to belt it out and sound like a rambling idiot. :applause2: By the way you do mobile detailing? Do you have a portable wash system or do you use your clients garage/driveway? I was tossing the idea around of getting more serious with my detailing and take on some clients but I don't have an inkling of what would be necessary to do so.
Very nice work! Wow cant believe you drop that far! Now find some more bad cars so u can bust out the AV!
Thanks! Have run into a tinted clear on some of the black Infiniti's as well. I was suprised by this one too. Thanks! Still came out very well even though the Denali only gets about 17mpg the way I drive it on the highway. :giterdone: Thanks Phil. All in a days work/drive my friend. I have another black S65 AMG on Thursday, but this one is a 2008.....Think I should try out the AV on that? :thumb:
Great job Bryan, both vehicles are perfect now. Must been a long drive back home from those 2.:thumb:
Well done two vehicles in one day wow...there is no way I could do that :thud: Both vehicles look great, brought the red back to life, thank you for sharing with us eace:
Thanks Dave! I always enjoy your writeups! Thanks Angelo! Not too bad of a drive. Heck most of my "local" clients are 1 hour away for the most part. Thanks Cobra! Thanks SC'd! Thanks Ryan! I have not even hooked them up to an airhose yet. Thanks Carlos! Sometimes everything just works out right, not often enough.
