Recommended Clay
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by Follmer, Nov 30, 2009.
  1. Follmer
    Follmer Birth of a Detailer
    Which Clay should I buy for my use on my pickup and other vehicles. I would like to organize a kit like the thread below this. I didnt know what you guys used and what purposes they all have.
    Thanks
  2. supercharged
    Sonus Green woulf be my choice...
  3. togwt
    This article should answer most of your questions on clay
    Detailer’s Automotive Clay - Detailer’s Automotive Clay - Detailing Bliss Forum
  4. 911Fanatic
    It will all depend on how badly contaminated your paint is as is discussed in togwt's article. I have found the Clay Magic Blue to be able to remove pretty much anything with ease when used in conjunction with their #49 Body Shine lube. Although finer clays may work, the amount of effort needed with some of the clays just isn't worth saving a few bucks. I have only had the CM Blue marr the paint on two vehicles in 17 years. Both were black RRovers.
  5. Follmer
    I have some water spots and would that Hi-Tech Body Sponge work for me? Is it a good all around tool?
  6. Follmer
    From the write up the Hi-Tech Body Sponge would cause surface marring. What product can I use to minimize surface marring but take out water spots on a black vehicle?
  7. Darkstar752
    Darkstar752 Horizon Detailing
    Danase Water Spot Remover
  8. pektel
    pektel DB Forum Supporter
    What about CG water spot remover? I have a full bottle, but haven't had a chance to try it yet.
  9. Darkstar752
    Given that Danase Wet Glaze and CG Ez-creme are almost the exact same product, I would say Danase and CG water spot remover are probably the same thing too.
    BTW OP, go with clay magic blue if you are removing contamination. For water spots, use a water spot remover or paint cleaner, tarminator for tar, etc.
  10. Twisted007
    Twisted007 Banned
    I have to 2nd this unless you can get ricardo clay bar.
  11. Follmer
    Thanks guys! So many products out there.. Tough decisions lol. We are detailing my grandpa's corvette now :D
  12. slanguage
    sonus green is a great clay bar, and so isnt DP universal clay.
