When im cleaning coated leather i used Meguires apc at 8:1 ratio,light cleaning, works very good with horse hair leather brush agitated lightly, my question is for protection I use Aerospace protectant with small microfiber pad to apply, will this product work for coated leather seats?,,any insight will help, is also use it for all interior plastic in vehicle..thanks.
For UV protection 303 can't be bettered. My choice for interior - 1z Plastic Cleaner (Plastik-Reiniger) - an intensive, non-corrosive, non-acidic two-phase deep cleaner that removes grime build-up, scuff marks, bitumen (tar) and nicotine thoroughly and effortlessly with dust-resistant anti-static action. Use to clean armrests, door handles, shift knobs, vinyl seats, pedals, dashboard, storage compartments, tires, rocker panels, wheel wells, and etc. Water-based formula is biodegradable, silicone and formalin-free as well as environmentally friendly. Follow-up with a treatment of Iz Cockpit Premium There is no such thing as a permanent UV stabilizer, it a matter of physics, not chemistry. Providing protection from ultra violet radiation (UV) is very important to avoid photo synthesis (colour fading) particularly in an open-air roadster/convertible UV protection is a sacrificial / renewable component; this is due to the UV protection layer being degraded by exposure to the elements (sun, sand, road or sea salt, and etc); so it is imperative that you renew it and needs to be re-applied on a regular 45 to 60 day basis (dependent upon location climatic condition) Iz Cockpit Premium – an interior care and protectant developed specifically for that original factory look. This is a treatment spray for all interior components including the dash, vinyl seats, door handles, trim, navigation screens, stereo head units, and clear plastic. It has very limited cleaning ability but it provides UV protection for interior materials. The gentle formula is water-based and free of oils providing a matte, original showroom finish. Non-slip finish allows for application on the steering wheel, shift knob and both finished leather and vinyl upholstery. For the potection of finished leather-Leather Master™ Protection Cream – (Not for use with N-Nubuck / Alcantara®) an aqueous (water- based) protector that places an invisible, breathable sacrificial barrier between you and your leather. This system is for you to protect your Leather first, and then follow a routine of cleaning and re-protection. This way you are not actually cleaning the Leather's original surface, but cleaning from the surface of the protection. Since some leathers are very porous, the Protection Cream prevents stains from absorbing deeply into the leather and becoming nearly impossible to remove easily. Usually, protected finished leather that have cracked or peeled is not from use, but from body oils and perspiration that have settled down into the grain of the leather and started to dissolve the finish over time. The Protection Cream will assist in preventing the cracking & peeling when proper cleaning is also done in combination.
That is what i was looking for, thanks very much on this subject,,well thats more products to invest in...
