http://detailersdomain.com/carcareproducts/NEWPRODUCTS/UberSuperDryingMicrofiberTowel.html What is the size on this? Is there a label sewn in? What weight and blend is it. Thanks
They are the best i have ever used. I love them. They are very soft, and super absorbent. They glide across the paint surface. From all off the drying towels i have used, these are the best to date.
How do they compare to the Adams and Uber waffle? I'm new to this and trying to decide which way to go.
The blue uber drying towel is similar to the Adams towel except the uber one is larger and a better deal. The super drying towel is huge and plush. I like both towels and use either one depending on the car and it's condition. I would get either of the uber towels and you won't be disappointed because there awesome.
The Adams white waffle towel is much softer than the Uber blue waffle. With that being said the Griot's garage waffle is softer than the Adams. I'm not a fan of the super plush drying towel and perfer to dry the car with compressed air and use a waffle on the windows so softness dosn't matter.
I really never undrestood why people use air compressors to dry there car. I get why people use the "Metro" brand dryer and electirc dryers, but oil based compressors dont seem like a good idea. All oil lubricated compressors put compressor oil into compressed air tanks and lines. As a compressor gets older, the migration of oil usually increases. As oil separators wear out, or are not cleaned as recommended, more compressor lubricant oil is allowed into air line and ends up on what ever your spraying. Unless you have a dedicated compressor for detailing and replace the AOS every year i would never use it on any car. (my opinion)
I have towels of varying softness from various sellers but really have not seen any real direct correlation of softness to performance or safety.
Mine has a filter after the compressor to stop moisture and rust coming thru. I assume it catches oil since my car is not greasy after. It comes down to cost I already own a air compressor that has uses other than just blowing air.
leaf blower on a car that has LSP, a car that has none is a PITA to used forced air to dry it. ill bust out the peak drying towel and knock it out in 5 minutes or so, but I will still used forced air on the cracks, headlights, emblems etc.
