Question on rotary
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by yukonon22, Jun 15, 2008.
  1. yukonon22
    yukonon22 Wax on..Wax off
    I got my first makita and when i was using it, it seems to bounce/ skip around edges and curves. Am i doing something wrong? also what speed do you usually work with it?
    Thanks
  2. D&D Auto Detailing
    What pads are you using? Speed depends on what polish you're using and what you're doing. For a beginner, Id stay below 1500.
  3. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    Sounds like you are using a foam pad with to little product and not using a smooth pass.
  4. yukonon22
    yes foam pads. Menzerna and 3m polishes. I was just playing around with it. Ill try more product and smooth passes. Thanks
  5. Asphalt Rocket
    I would suggest getting a wool pad to play with, they are alot easier to work with and this will help you get the feel for the rotary better.
  6. Denzil
    It sounds like your pad is drying up on you. I would suggest the PFW pad and I usually start at speed 1 (700rpm) on the Metabo and go to 3 (1500rpm) and back down to 1.
