Question about pre-wax treatment
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by TONY MONTANA, Jun 6, 2010.
  1. TONY MONTANA
    TONY MONTANA DB Forum Supporter
    i have a question about pre-waxing if im going to use a product (such as sv cleaner fluid or zymol hd cleanse or etc) and i want to use a sealant under my wax for extra protection do i use the pre-wax treatment before or after the sealant? if i use it after the sealant will it strip the sealant? if i use it before the sealant will it help the sealant bond better to the paint? thanks in advance
  2. detaildoc
    detaildoc Guest
    Any cleaner fluid will remove your lsp, so if you want a sealant under your wax, you will need to skip the cleaner fluid. If you use a cleaner fluid first, you won't be able to use the sealant as it won't bond to the paint. A sealant needs a clean surface to bond to the metal. You have to use either the sealant or the cleaner fluid before your wax, you can't use both.
