Question about Makita 9227
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by rtrt2889, Dec 2, 2008.
  1. rtrt2889
    rtrt2889 Birth of a Detailer
    I have been using the Porter Cable for about 2 months now. And I want to try a Makita 9227. I heard that it was a good rotary. I have a few questions regarding a rotary in general.
    How is a rotary differ from a PC in performance wise? Let's say I use a purple wool pad with Power Gloss using a PC, how would that differ on a rotary. I have watched Nica's video on polishing and the movement he using looks similar to a PC. Will I need nee to apply less pressure? or keep it moving more because I heard since it is a rotary, it is not good to keep the rotary static on the clear and always have it moving along the panel.
    As for the hook and loop backing plate with the 5/8" x 11 spindle threaded. Is it all 5/8" x 11? I want to get the 3m back plate, I heard a lot of good things about it. Which size backing plate would you recommend to start with? A 5 inch one? On detailers domain, Phil has a 3m back plate but I do know what the size is.
    With that said. Is there anything I need to know before I buy a Makita 9227. Thanks! :headbang:
  2. Denzil
    The rotary has a uniform circular motion while the PC has a "dual-action" or "random-orbital" motion. With the rotary, you'll achieve more correction power due to its consistent/uniform motion whereas the PC you'll achieve less.
    There's actually a huge difference between both machines when using the same pad and polish combination. You may need to apply less pressure but it's more advisable that you start with lower RPMS (< 1200) to reduce the risk of damage. In essence, keep it moving!
    The 3M backing plate that Phil offers is compatible with the Makita 9227C or any U.S.-sold rotary machine. It would be the perfect BP to start with and use for its entire lifetime and it measure just slightly under 5 inches in diameter.
    Oh and remember, respect the machine and you'll achieve great results! If you don't have enough courage to practice on your own vehicle, go out to a junkyard and buy some scrap panels to work on. Good luck!
  3. rtrt2889
    Okay thanks Denzil :worship2:
    I am going to buy one on ebay. I think it is $169.99 for a 9227 plus a bag too.
    And 30% off using live cash back, that should come out to $127.49 after all said and done. :applause2:
    Good advise, I live near a junkyard too, so I'll stop by and see what they have. I'll put your advise to good use.
    Thank you :mounty:
  4. Buddy
    Great deal on the Makita. I've never seen it at a price that low. I paid 169.00 for the whole kit. 9227CX3 Thats a great deal.
  5. billyblooshoes
    i just picked up a makita on ebay. six months old for $90. i love the damn thing. needless to say i am pleased.
  6. Berscht
    Berscht Jedi Nuba
    The rotary is a big difference. I went from using a UDM to the Makita and wow... the best part? No more vibration! The cutting power is much greater compaired to the PC. You will find that you will be able to use a less agressive pad/polish combo to remove defects that would require much more aggressive combos with the PC
    The backing plate on detailers domain is a 5 inch I believe, but maybe others can chime in who know for sure.
    The only thing I would say to expect befor buying is a great machine, However where the cord enters the machine fell apart quickly on mind and had to be replaced, and I have heard this happen to numerous people on the form.
    Good Luck with your Makita, you wont regret it!
  7. rtrt2889
    Thanks for all the tips. :thumb:
    Sounds that this is a great machine. I think I will getting one of Phil's 3M backing plate too. I heard I should start off with LCC pads. What other pads do people use with with the makita/3m backing plate.
  8. Duratys
    Duratys Welcome to Detailing
    I use Sonus and LC Pads. Find a style of pad you like and learn it well.
  9. Berscht
    Berscht Jedi Nuba
    Meguiars 6 inch pads are great, I just ordered some Sonus pads off e-shine so I will have to see how they preform. A lot of people on the forum use 3m pads but I cannot comment on them as I have not used them.
  10. togwt
    Do a search on DB orFor more information see “Rotary polisher usage tips” one of the detailing articles on DetailingWiki; (Wikipedia® is a registered trademark of the Wikimedia Foundation) a series of informative, knowledge based, unbiased articles dedicated to automotive detailing
  11. rtrt2889
    The Makita 9227 is on it's way.
    Thanks for all the tips and advice. :thumb:
    I can't wait to start using it. :applause2:
  12. razr007
    razr007 Banned
    It takes time getting use to it but in the end it i the only way to go
    Get an old used hood from junk yard and practice on it until you get good so you don't damage your paint on any real cars your detailing
    Hope this helps
  13. rtrt2889
    My Makita has arrived!!
    it's a kit that came with the makita, a bp, a wool pad, a glove, and a calender.
    I can't wait for my 3M backing plate to arrive. :applause2:
    And the calender that came with it....it's up on my door now. :popcorn:
  14. Carn
    Carn Welcome to Detailing
    Congrats on the purchase, you can't go wrong with the 9227 ;)
    On a side note do you have any part number or code for that bag...ours never came with one :(
  15. razr007
    razr007 Banned
    wow thats a great price who did you get it from an how did you get it so cheap i might buy a few more.
  16. Buddy
    Glad to see it arrived. Congratulations on a great buy...:thumb:
  17. bryansbestwax
    Mine didn't either, it's a States thinig, lucky buggers
  18. Buddy
    Hi Carn, The bag part # is 821007-X...21 inch heavy duty tool bag...:thumb:
  19. rtrt2889
    Thanks. I can't wait to use it. :applause2:
    It was 162.99 + 15.95 for S/H
    But I bought it during ebay/live.com cash back. So I ended up paying $138.19 for it :afro:
  20. Carn
    Thanks Buddy, appreciated ;)
