Restore your trim to as new condition Our revive trim dressing is designed to protect all exterior vehicle plastic trim, and breath new life in to dull or fading trim. Helping to prevent further degradation, leaving a natural, non greasy as new look. Heres how to get the best from your trim: Before: The first job is to thoroughly clean the trim, in this instance we are cleaning it individually, however this stage can be incorporated in to the wash process. Using our AF Citrus Power and a soft bristle brush work the cleaner in to the grain, this removes in ground dirt and old dressings: Once the trim is clean and dry, you can set about applying AF Revive trim dressing using a foam applicator is advised, we are using our waxmate applicator: The results: Also useful for restoring wiper arms: And all other exterior trim, Mirror housing before: After: Creates a weather proof dressing that lasts: Click here to purchase Auto Finesse Revive Trim Dressing
not sure we will be doing a fairly large order of AF as we are very low. the waxmate is very similar to the Uber red notched pads. not sure we will bring that one in. but I can order them for you if you like.
+1 on the wax mates. Been bummed I can't get any more. I bought 6 of them right before Martin stopped dealing AF, starting to run low!
