Product Showcase: Auto Finesse Rejuvenate
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by MartinD, Mar 7, 2012.
  1. MartinD
    MartinD DB Certified Manufacturer
    Product Showcase Auto Finesse Rejuvenate:
    Rejuvenate is our pre wax cleanser, and like all other good pre wax cleansers it contains some light abrasives as well as glazes to not only deep clean the paint prior to the application of an LSP but to also enhance the finish beyond that of just a wash and clay, it will also remove any light marring that may have been inflicted in the prior claying stages.
    When creating this product it was extensively tested with lot of waxes as well as our own so, the goal was to create a good deep cleaning paint cleanser thats not fussy to use or to oily but leaves a good finish, the original and primary application method would be by hand with a medium foam or microfiber applicator pad, however as shown below it's also capable of being successfully used by both rotary and orbital too.
    Our test hood:
    And the line up:
    First test is to demonstrate the product by hand application:
    Small amount applied to the pad:
    Worked in to the surface:
    Briskly buff the residue:
    Leaves a decent result, not perfect but much improved for a single hit by hand:
    The next is to demonstrate the results when used by machine polisher...
    You will notice we moved the tape line along a few inches to make it a fair test. Small amount applied to a polishing pad:
    Spread and worked through till clear ranging up to 1100-1200 RPM:
    And the results from that:
    Thanks for checking out the thread! If you have any questions about the product or demonstration ask away.
    -Martin
  2. chemgys99
    chemgys99 DB Forum Supporter
    Awesome! Can't wait try it out.
  3. MartinD
    It is easy easy easy to use. I really think with enough training my dog could do it :D
