ProBuilt Defender Uplight
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by Chaseme, Feb 7, 2012.
  1. Chaseme
    Chaseme DB Forum Supporter
    I want this thing for side lighting:
    About $200USD at Fastenal
  2. sikedsyko
    sikedsyko DB Forum Supporter
    Looks pretty cool, but $200? :thud:
  3. Stokdgs
    Stokdgs Detail Master
    Thanks for posting this !
    Looks great for other things but I am not sure 3250 lumens is enough.. I need to see what 2 500w halogen lights produce in lumens..
    Price is pretty high isnt it? Maybe LED's should be that high ? Am I just high ?? :) :) :)
    Dan F
  4. drew935
    drew935 Auto Salon Works
    Yes $200 is a lot. It's flourescent and not LEDs Dan. Halogens produce lower lumens than flourescent and LEDs. ;)
    There has to be a better setup and cheaper than this :shead:
    IMO it's not bright enough.
  5. 911Fanatic
    Each 500watt lamp is around 10,000 lumens I believe.
  6. drew935
    /\/\ that is correct ;)
  7. Chaseme
    I guess I'm a minority but halogens are generally too bright for my tastes. The fact that this is a light bar is a huge bonus as I will be able to see light bend evenly and uniformly when hitting the finish.
  8. drew935
    Do you mean too hot or too bright? Bright is what we want w/o the heat unless it's cold outside. The plus is that LEDs and flourescents produce less heat.
  9. Chaseme
    Too bright. I have sensitive eyes.
  10. drew935
    Wear yellow lens work glasses ;)
  11. Auto Concierge
    You need halogens to pick up certain defects, I have T5 high output lights for general lighting, the halogens, LED flashlight, Infratech and of course "Mother nature" sunlight. With all these diferent lighting choices of ambient light I never get "Suprised" by pulling a car outside and going Cr**p...................... I just wish I had a better halogen light set up to buy as the stuff in the chain stores(From China) falls apart with the quickness.
  12. Stokdgs
    I knew those Pro Defender lights were flourescent, thanks. LED's would be great provided they dont cast that blue light like I saw them do this past Christmas on some people's christmas lights.
    I will always like the 4 - 500w each, Halogens I have and they seem to pick up most defects. Still have both LED and Halogen Brinkman lights, and occasionally, a little sunlight up here where the trees are giants and the people have equally sized ego's.. :)
    Dan F
  13. hamza7
    hamza7 Welcome to Detailing
    I don't know how crafty you are Bob but here http://www.autopiaforums.com/forums...ment/38456-my-halogen-light-tower-wheels.html
  14. Chaseme
    I've admired your setup for awhile now. Thanks for the input Bob.
    Thanks for sharing Hamza. That's something I need.
