Pressure Washer
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by jlt23, Jan 16, 2014.
  1. jlt23
    jlt23 Any Rag Vehicle Washer
    What pressure are you running your pressure washer? Do you change it when washing/rinsing vs foam canon? I picked up a kranzle over the holidays and haven't had a chance to use it yet. Planning on using it this weekend.
    Thanks
  2. MGEVOX
    MGEVOX New Member
    I'm trying mine tomorrow as well definitely didn't spend the bread you did but hopefully it will be a joyful foam party!!
  3. 911Fanatic
    Whats the max psi and gallons per minute your pw makes?
  4. jlt23
    1400 psi and 2.1 gpm. It's a kranzle 1122tst
  5. MGEVOX
    MGEVOX New Member
    1900 and 1.5.
  6. MGEVOX
    MGEVOX New Member
    I got some crazy thick foam with honeydew even on the lowest setting on mine I think I'm going to use even less product next time I didn't even use much at all I was surprised.
  7. jlt23
    Glad to hear. I wasn't able to use mine since I had to go to work. I read on another site that they were setting their pressure washers around 100 bar
  8. Bunky
    Bunky DB Forum Supporter
    I decided to actual measure what was coming out of the reservoir to understand actual dilutions.
    My Kranzle puts out 2.2 gallons (measured) with the Cam Spray foam cannon that Phil used to sell. It pulls 10 oz of product from reservior in 1 minute at wide open so in my case I am getting about 1:100 product. For Honeydew, even if you believe CG's optimistic dilutions, I was dispensing fare more more concentrated that rated (1:500). It was thick and sticky enough for me.
    Honeydew (~1:100 dispensed)
    Avalanche (~1:100 dispensed)
  9. detailersdomain
    the foam cannon we now sell is the one by MTM Hydro it works great on the 1122. No issues nice foam.
    I like it always on the thickest setting.
  10. Bunky
    I see it is now back in stock. It wasn't during the Christmas period and New Year sale period. I had an itch at the time to get one.
  11. MGEVOX
    MGEVOX New Member
    I got one made for my POS washer that looks like the MTM mine is an ar blue clean one I'll get pics when I do my car did the wifey scar first and yea I know I used way to much honeydew I put a little less than 100ml in the container and put warm water in the rest and it was thicker than yours on the low setting. Probably stripped the PNS from the car.
