Ok so I have a Briggs and Stratton Intek Pro 206 Pressure washer and it will not start. I changed the oil, put in fresh gas, checked the spark plug and still it won't start. Anybody have any ideas? I can't figure this thing out. From what I can tell there is air, fuel, and spark. Anyways any ideas or thoughts would be awesome. Thanks guys.
Spray a small amount of gas down the carb, if it fires right off you have a carb/fuel delivery issue. If the engine uses a vacuum pull fuel setup (ie tank under the carb) they are very sensitive to fuel gumming as they don't have a ton of power to suck the fuel up. I would remove and clean the carb and tank and try again.
