preparing freshly paint door before sealant/wax?
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by ramprun, Mar 31, 2011.
  1. ramprun
    ramprun Any Rag Vehicle Washer
    Hi all,
    I am just wondering if it is necessary to clay or polish when it comes to a fresh paint job. I got into an accident couple weeks ago that requires repainting one of the door. I know that it is necessary to clay the paint of new car because of rail dust during transportation of new car but i only live a couple of miles away from the place i have it done. will it still accumulate dirty particles enough to justify claying or other paint correction before waxing?
  2. kyoshiro
    kyoshiro DB Forum Supporter
    i would say you should actually give it a couple of weeks before you actually do any claying or polishing to it because the paint needs to fully cure/etc.
  3. Bmer89
    Bmer89 DB Forum Supporter
    Depending on the paint used, cure times can be as much as 3 months, before you can wax it. But you can also get it cured and be done with it.
    Talk to the paint guys, they should know :thumb:
  4. Reflect
  5. domino
    domino Welcome to Detailing
    two lines of thought re new paint
    some say with modern paints/oven it cures as soon as its left the paint booth
    some say it takes weeks
    think of this way, modern cars arent left in the factory for two weeks before they are polished and sent out. In some factories, it's only several hours between the car being painted and corrected
    i personally wouldnt heavy cut or heat up the panel too much when correcting, nor would i use a sealant for a few weeks
    a fine polish, low heat and a carnauba is what id do in the short term
  6. Misha
    Misha Nuba Guru
    depends. if it was baked then its pretty much cured as soon as it leave the booth but body shop said still better to wait couple weeks.
    if it wasnt baked then you should wait 3 month or so
  7. ramprun
    Thanks for all the help guys. so long story short, i need to talk to the person who paint my car about the curing time before claying and polishing right? I like to know why polishing is required if it is a new paint job.
  8. Bmer89
    It's not so much the claying and polishing, it's trapping uncured paint under an LSP that may cause issues. And depending on how good your painter is with a buffer will dictate how much polishing is needed on those areas. I've seen lots of sanding marks and pig tails leave the booth...
  9. yamabob
    yamabob Two Bucket System Washer
    I've been only into the higher end of detailing for a short time ,but I've been painting for..........well since the mid eighties. No matter how good the gun and painter are-no paint job is ever flawless. To achieve that mirrored show look a color sand is required. as soon as the paint is no longer green,it can be sanded and polished. Air dry would be 24-48hrs and uv cured (depending on the clear being a high solid-4.2 or low solid-2.1) can be after 2 hours. A glaze can top the paint,but I recommend to stay away from wax's and sealants for several months till it has fully out-gassed. It's a hit or miss thing. You can trap solvents that are still gassing out and get what is know as "solvent pop" little pin holes. Best to wait.
  10. ramprun
    thanks for all the great advise guys. i just got the car back today and i think i will leave it in the sun so it will cure faster. I will also wait couple months before attempting any polishing and waxing. i am still new at this and a little scare to pick up a buffer at this point. I will study your posts and continue to learn more about detailing during the mean time. thanks again.
