Porter Cable as sander?
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by SSTG, Dec 20, 2008.
  1. SSTG
    SSTG DB Forum Supporter
    Does anyone know what is takes to make the PC a wet sander? And where to buy the stuff at? I seen Clark useing it as one. :idea:
  2. MrPolished&Waxed
    theres a 3m system thats velcro, i think the pads are called trizact? you would need the bp and the sanding pads.
    heres the bp
    wet sanding discs
  3. rtrt2889
    rtrt2889 Birth of a Detailer
    So if I buy the sanding pads, can I use my current BP on my PC?
    And sanding pad itself, do I just stick the sand paper onto to pad, then straight onto a backing plate?
    -Thanks
    Edit: Wow...I have no only found it sold in bulk...50 and 100 for $100 plus. Does anyone know where it sells individually?
    Edit: I think I found it, but I don't exactly what to get: http://autobodystore.net/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=M3
  4. 911Fanatic
    I have the 3M Trizac system for my pc and it does work well. There are advantages to getting an actual RO Sander because it has a shorter throw but I'm no expert on these things so maybe someone else can chime in here.
  5. rtrt2889
  6. Nica
    I'm sure about using the PC as a sander...I'm sure it's capable of working as others have used it....but I'll be using my RO sander as it's meant to be used....I'll be putting the RO to good use tomorrow and I'll be picking up the 3M Trizac disks as well. Look forward to putting these tools to good use :thumb:
    But I'm curious about the PC being used as a sander. I know others use it as a sander but I wonder if it leaves pigtails behind? Any who I'm no help, I got more questions then answers :sorry:
  7. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    The pc is used as a wood sander. My dad has one for over 20 years that he uses in his wood shop. Just like Menzerna FPII is in alot of woodworking suppliers as a wood polish.
  8. 911Fanatic
    Yes it does leave pigtails as the throw on a PC is a lot larger than an actual RO sander. I believe its 5/32 instead of 3/32 on a sander. Makes a big difference apparently.
  9. Nica
    Interesting, I used my RO sander today and it worked like a champ..made quick work of some what deep scratches..what a time saver :worship:
    Now I need to get more sanding discs.
  10. D&D Auto Detailing
  11. milabfocker
    milabfocker Jedi Nuba
    I've used my PC as a sander; works fairly well. It will leave pigtails; however, they haven't been overly difficult to remove in my experience.
    Here is a link to the Mirka Abralon abrasive discs. These have an interface pad attached to each disc so any hook and loop backing plate can be used.
    Mirka:Abralon - 8A Series
    In order to use 3M's Trizact abrasives you must use one of their hook and loop interface pads.
    3Mâ„¢ Hookitâ„¢ II Soft Interface Disc Pad, 05274, 6 in 1/ea - 3M Hook-It II Pads and Accessories
    These interface pads can be purchased in various sizes.
    Hope this helps.
