Polished Bliss: Gloss-It UK Debut (Lotus Elise)...
Discussion in 'Professional Detailer's Studio' started by Clark, Nov 3, 2008.
  1. Clark
    Clark Two Bucket System Washer
    Hello all!
    This detail was a 3 day correction detail carried out at the end of this week and I'm afraid to say it was a case of fixing someone else's mess from the dealership yet again (those that are regular readers of our details will know that alot of recent work has come from poor dealership prep etc).
    It was also an opportunity to put to use some of the Gloss-It products that we are going to be taking stock of next week :thumb:
    The car in question was this rather nice Supercharged Elise, which looks great in red - not many in this colour going around :)
    Already in the morning sun there was evidence of paint defects:
    But before I can do anything about them I have to get the car washed, so up first with the pre-foam - Hyper Wash @ 60 degrees and left for 5 minutes:
    Then rinsed off:
    The wheels were sprayed with Menzerna 7.5 Tyre and Wheel Gel and then agitated with various brushes:
    The arches and tyres were also scrubbed with a new high strength APC currently on test:
    The shuts and exterior trim were cleaned with the same APC and a brush before rinsing:
    Although not really needing it, the hood was cleaned just to be on the safe side :)
    After the roof was thoroughly rinsed, I washed the car with the 2BM and Gloss-It Gloss Shampoo (love the smell of this stuff!):
    Tardis was then used to remove any minor tar spots, including the inner arch lips:
    Before:
    After:
    Another quick rinse followed and I then put the car inside for claying.
    Another Gloss-It product for this, the green mild:
    This was about as dirty as the clay got:
    I then dried the car off with one of our new drying towels:
    Now dry, it was time to properly inspect the paint with the 3M Sun Gun.
    This revealed signs of previous heavy machine polishing with no refining what so ever:
    Sanding micro marring:
    There was also quite alot of RIDS and the odd scuff etc:
    The usual bits were removed to help make polishing a bit easier:
    The paint gauge was checked for accuracy...
    ...and then used to determine how much paint I had to play with (no metal panels on an elise so the composites gauge was used):
    The readings revealed healthy levels all round with no signs of previous paint work.
    After playing about with pad and polish combinations (106FA and menz 3.02 were tried but didn’t quite remove the deeper stuff) I settled on Gloss-It Evolution Extreme Cut. I've been using this quite alot recently and it's comparable to the likes of 3M Fast Cut Plus. The Gloss-It polishes are designed to work with Dual Action machines but I’ve grown to really like the Extreme Cut with the Rotary :)
    I worked the polish with a 3M Polishing Pad @ 1500rpm's, continually checking panel temperatures:
    Result:
    I wasn’t overly bothered about finishing down all that well so in some of the other correction shots you'll see some light buffer trails courtesy of myself :D
    Some more correction shots, in no particular order I should add:
    Rear bumper before:
    After:
    50/50 rear end:
    Spoiler before:
    After:
    Front bumper before:
    During:
    After:
    Before:
    After:
    3" 3M Pads were used at various times for the tighter to reach areas:
    Door shut before:
    During:
    After:
    Lower front bumper:
    During:
    After:
    Door fully corrected:
    With the Correction work all completed, I then refined the finish further with Menzerna PO85RD and a 3M finishing pad.
    The armour fend on the lower back 1/4 was polished up with Blackfire Gloss Enhancing Polish:
    This brought the total polishing time to just over 20 hours, which included a 10:30pm finish on Thursday night.
    The Elise isn’t a big car but there is alot of paint to polish and a huge amount of awkward sections to break up so they can be polished properly, hence why the correction stage can take so long :)
    The car was then dusted down with a wool duster and I used masking tape to clean up the hood, which was then protected with 303 and left to dry while the rest of the car was finished:
    The paintwork was then given a full wipe down with Menzerna Top Inspection to remove any polishing oils:
    LSP was the new Gloss-It products. There are several to choose from but I opted to go with Signature Gloss first:
    Please Note that this is not the bottles that the product comes in. These are just the sample bottles Rich from Gloss-It sent us to let us decide if we thought they were good or not (luckily we thought they were :D).
    The SG was applied by the G220 and a glazing pad. It can be applied either by hand or machine but I prefer the machine for some reason :)
    The hard to reach areas were done by hand though:
    Once buffed off, I topped the Signature Gloss off with Concorso Gloss - again applied via the G220:
    The wheels had been sealed the day before by Marsha (who had polished up the tailpipe nicely too) so it was a case of dusting them down and then applying Gloss-It's Tyre dressing.
    I've grown to love this product too, you just lightly mist it onto the tyre wall...
    ...then after 5 mins and a quick wipe round with an applicator it leaves them looking like this:
    The tyres received 2 coats of the dressing, one at the beginning of the detail and one near the end.
    The interior was given a quick going over too, including a bit of spot cleaning with the Gloss-It leather cleaner and then fed:
    The inside glass was cleaned with Eimann Fabrik and the outside glass/headlights were treated to Rain-X. All interior surfaces were wiped down with APC and the mats were given a light shampoo.
    The last step to complete the detail was one final wipe down of the paintwork using Gloss-It gloss Enhancer QD:
    After using this for around a month now, I can safely say it is now my most favourite QD - As you can probably tell from how much is left!
    The owner turned up just as I was giving the car it's final wipe down so we didn’t get as many pictures as I'd have liked, but here's the best of what we got (some are taken with my camera and some taken with Rich's):
    By now you'll all know that I give an honest opinion and review of products so hopefully you won't see this as a blatant plug just to push this new line, and at the end of the day - If they weren't good enough, we wouldn’t be using or selling them :thumb:
    Thanks for taking the time to read,
    Clark :cool:
  2. Buddy
    Hi Clark, What a great save. You did a beautiful job. To bad about those Dealers & body shops...:shrug:
  3. Tampa-Brian
    Tampa-Brian Any Rag Vehicle Washer
    Im really surprised the gloss it compound was able to provide such correction via rotary. I guess in florida the humidity may play a role in keeping every water based polishs' cutting ability to a minimal. I used two of their polishes both via rotary and da, and experienced very little correction.
    Nice detail, how do you like megs interior brush on wheels? Never thought of using it on exterior surfaces.
  4. Clark
    They do take a bit of getting used to via rotary and i've found that the Extreme Cut is the one that works best out of the 3, which is weird as it is water based like all the others - however with the DA I've been impressed with them, which is the most important thing as I dont really plan on using them much with the rotary as i have Menzerna/3M for that but for the enhusiasts that generally use G220's/cyclo's it's another choice when it comes to polishes :thumb:
    The slide lock brush is great, I use it for various jobs throughout a detail, not just the interior :)
  5. Hum-Benz
    Hum-Benz Wax on..Wax off
    Great job with the dealer mess!
  6. 911Fanatic
    Fantastic job once again, Clark. Car looks beautiful in red! Can you use the QD over any LSP, sealant or carnauba?
  7. P1et
    Stunning! Red is just as rewarding as doing a black vehicle, in my opinion!
  8. Nica
    As always Clark great detail and I always enjoy yoru write up's well done :applause:
    :worship2: :worship2:
  9. Clark
    Yep we've used it over both with no problems at all mate :)
  10. Clark
    Cheers mate :thumb:
  11. ///M LifeStyle
    ///M LifeStyle Birth of a Detailer
    great work!
  12. Calgarydetail
    awesome awesome work as alwas clark
  13. BrendanS
    BrendanS Welcome to Detailing
    just a quick question, in the first picture and the pictures of it in the wash stage, what is the car parked on or over?
  14. bryansbestwax
    Wash mat, depending on run off water regulations, it is required by law and you could be fined without using one
  15. MadOzodi
    MadOzodi Nuba Guru
    Great work! Man, the Lotus Elise (and all its variants) is downright impossible to get into. Even harder is getting out....and I'm vertically challenged!
  16. 911Fanatic
    Here is our man Clark working on another Lotus!:thumb:
  17. MadOzodi
    MadOzodi Nuba Guru
    LOL, having the top off makes it so much easier...the one I was getting in and out of was a coupe...I just said screw it and got out headfirst on my hands. As fun as the ride I had in one was...no way I'd ever own one...but now I know how to detail one thanks to you! :thumb:
