Polish dust and re-introducing swirls
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by Rustbucket, Jan 18, 2009.
  1. Rustbucket
    Rustbucket Birth of a Detailer
    Carn and I were just discussing this, this weekend.
    The fast cut he was using made a fair bit of dust and I was following him with the yellow 3M pad and FA. But we did start to worry when we were wiping the dust away.
    So, a quick experiment followed. Carn simply put some of the dust from the Fast Cut on to a micro fiber and wiped a spot we had just polished with the FA. We instantly saw some fine scratches appear.:yikes:
    Just wondered if this could have simply been a "fluke". This did however make Carn and I change our minds on how to work when using a compound. We felt the whole car should be compounded first and then rinsed. Only then should we start finessing.
    Just wondering what your guys thoughts are on this.:shrug:
  2. ScottieB
    ScottieB Jedi Nuba
    When I learned to compound at a bodyshop, we were told to complete one stage before moving onto the next. So when the boss says do something, you do it. I guess your demonstration says why.
    PS. I didn't really learn how to polish until this site!!
  3. infinity
    infinity Any Rag Vehicle Washer
    a fluffy duster comes in handy for this, looks like candy floss on a stick if you know what i mean.
  4. Nica
    :nod: yes, I've found that when your compounding and removing the dust that is left behind you have to be careful. Especially when your dealing with a black colour vehicle. Also what I normally do is if I'm compounding, I compound the entire vehicle. Flatten out all defects for the entire vehicle, once I'm satisfied with the compounding I either re-wash the vehicle or I use the Zymol duster to remove the dust. Then I continue with the next polishing stage.
    Just my :2cents:
  5. infinity
    that,s the one ^^ without the branding works a treat
  6. 911Fanatic
    You're awesome!!
  7. eyezack87
    eyezack87 Guest
    Zymol Duster (or knock off) FTW :applause2:
  8. porta
    porta Jedi Nuba
    I usualy foam the car with a alkalie degreaser and rinse it off with a power washer. Very effective and fast.
  9. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    If the vehicle is very dusty, it gets rinsed. Plus I do one step at a time also.
  10. Berscht
    Berscht Jedi Nuba
    From past experiences I have found that after compounding a foam gun soak followed by a high pressure rinse is a lot less frusterating than going over the whole car, trying a get all the dust from all the little cracks.
  11. Carn
    Carn Welcome to Detailing
    Thanks guys, I figured as much seeing as how abrasive some compounds (especially the FCP) can be ;)
  12. billyblooshoes
    i use primarily menz powergloss for compounding and i too will do the whole car in my first step and then follow it up with a rinse to eliminate the risk of reintroducing swirls. i mean hey, our line of work involves being meticulous in all aspects, so why no take the extra ten fifteen minutes to re rinse/wash. just my opinion.
  13. J BELL
    J BELL Nuba Guru
    I tend to like doing an ONR bath with a new mitt after compounding..its fast and effective
