Pictures coming out too RED
Discussion in 'Detailing Bliss Lounge' started by FMINUS, Feb 28, 2008.
  1. FMINUS
    FMINUS DB Pro Supporter
    How do you eliminate this problem? I have teh Rebel Xti. And most of the shots are in AUTO mode.
  2. SpoiledMan
    SpoiledMan Birth of a Detailer
    Go to the menu and reset all settings. If that doesn't work it may need to go to a service center. Sammy's might also lend a hand.
  3. FMINUS
    U dont think its just the settings? they dont ALL come out too red, just some.
  4. Nica
    huh..interesting...wish I could help out the only thing that comes to my mind is the white balance? I have mine set to Automatic....but that's just me shooting in the dark though :shrug:
    I'm looking forward to read what others have to say about this though.
  5. FMINUS
    Does yours ever come out too pink? Its only a problem in the poorer lighting areas.
    I have it set on AUTO too
  6. SpoiledMan
    If you choose one of the program modes does the problem go away?
  7. brianja
    brianja Jedi Nuba
    What type of camera? Can you put up an example?
    It could be the lighting in the photo and that you would have to adjust the white balance to compensate.
    Often white balance adjustments are not available in AUTO shooting modes.
  8. Nica
    Pink..um..no...:shead:..I don't think so. I usually have the seeting to the "P" setting though so not sure if that helps :shrug:
  9. Duratys
    Duratys Welcome to Detailing
    My guess would be that in low light situations you will be better off setting the camera up manualy vs the auto mode.
  10. Scott's Mobile Detailing
    change your white balance..try that
  11. P1et
    When you're in a poor light situation, do you still shoot in auto mode, then the flash pops up? Or are you using the external flash?
    Get away from auto and switch to Av mate!!!
    And post up some examples if you can...
  12. richy
  13. FMINUS
    thanks for the help guys :)
  14. P1et
  15. iVTEC
    iVTEC Virgin Detailer
    hmm yeah white balance may help!!! my xti was complicated to use.. so i just returned it for now and got a ps3 lol! ill get one again soon...
  16. Nica
    Hey P1et, that is a great forum wow I've been reading quite a bit there and lots of good information thank you for sharing the link with us :hug:
  17. FMINUS
    OK now another question. The pics that PRINT out look darker than the ones on the computer......
    solution? :shead:
  18. adriankeith
    adriankeith Birth of a Detailer
    Naturally, photos are going to come out differently when you print because your monitor/computer at home isn't calibrated the same way photo printing places are. Where are you bringing your prints? You can actually have color correction done on your photos if they do any editing themselves (not necessarily color correction, but they should be able to bump up the brightness).
  19. FMINUS
    Im printing them at home on a HP 6980. Which is the "real" color? Whats on the screen or whats on the printer?
    And whats the BEST photo printer? And I mean absolute best without taking into consideration of price
  20. adriankeith
    I don't really know anymore as I haven't been putting much time and research into a quality printer. They can get really pricey mainly due to the ink in the long run but the type of printers i'm talking about use 6-7 different colors rather than your standard CMYK. That being said, there are still affordable printers that use these 6 cartridge setups that still make great prints. You have to take into consideration paper as well because that can also mean the difference between an OK print and a great print. I'll try to get back to you or post up some results in different price ranges.
    This link is a bit dated, but the information still stands Printer Primer info.
    I'll try to find you more info.
    Also, I'm not sure how big you're printing but I want to suggest a couple of places to check out that are recommended by some really good photographers (whom i've met with and gone on shoots with, stunning prints).
    The first:
    West Coast Imaging
    The second:
    El-Co Color Labs. Your professional lab for quality digital and optical printing
    Great prints, great pricing and probably some of the best paper. The websites should tell you how you should set up your photo for submitting. Turn around time is pretty quick as well as far as I've been told.
    P.S. How big are you printing? Just so I know what kind of printers I should be looking at.
