I just need some recommendations from those that know more than me on what products to use, and what method as well, to solve these following problems. First off, I have this horrible swirlmark/hazing going on in this particular section of the hood. Then I also have a few trim pieces below the windows that are stained. They almost have that "rainbow" kind of effect like gasoline and water going on. And my mirrors are faded, Back to Black is basically worthless for this unless I want to do it everyday, I have discovered.
Has your hood been repainted? And those mirror stalks look too faded to be restored with a dressing. You might have to dye them.
Be careful on the paint. Those beat areas look like the clear coat may be failing. Further paint correction can (and probably will) result in further damage.
