Pad choice for applying KAIO
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by bryansbestwax, Jul 26, 2008.
  1. bryansbestwax
    Which pad should I use for KAIO, I have blue edge wave or red edge wave pads. Also, I was thinking about using 600 rpm on my Makita, any thoughts?
  2. MadOzodi
    MadOzodi Nuba Guru
    I'm not sure about the edge pads, but I would suggest whatever is equivalent to a LC white pad. A little goes a long way so using a rotary might be overkill. I've never really thought of KAIO being used to correct any defects.
  3. Reflect
    I've never used the stuff but I'd imagine it's basically a finishing polish. I use SSR1 on a white LC pad. I agree it should be similar.
  4. bryansbestwax
    I use the rotary on low to spread the KAIO a little faster
