Did anyone see this deal? 5L TAW at $48 thats almost $17 off How does this compare to OPT Power Clean and what dillution?
Yeah, I noticed that this morning also. P21S TAW is a pretty sick product because of its surface safety and versatility. You can use it outside the vehicle at full strength or 1:1 for cleaning tires, wheel wells, as a pre-soak for lower panels, pre-soak the windshield and front bumper, etc. Can be used to clean engines, as a maintenance wheel cleaner, etc. You can even add a couple of ounces into your wash bucket to boost your shampoo's cleaning power. Dilute it 20:1 and take it inside to clean ALL interior surfaces. Optimum Power Clean offers pretty much the same exterior surface safety, but is stronger. OPC can be used on the exterior at full strength or down to 3:1 and is very powerful even at 3:1. But for interiors, OPC is supposed to be used at 3:1, vs P21S TAW's 20:1 ratio. I believe there are other members here using OPC on interiors at 10:1 but I cannot comment on that. I Just know that Optimum says to go 3:1 for interiors. Because P21S TAW focuses heavily on surface safety, you have to brush or agitate the surface you are cleaning to get the maximum performance out of it, whereas OPC works better as a spray-and-rinse type of use. Makes sense?
Go OPT Power Clean 3:1 for this purpose. It will strip waxes and sealants no problem and is safe on all exterior surfaces.
That's a heck of a price You can get 20% off that right now with their coupon too. Too bad I've already got a gallon.
I don't think so, i tried bc their p21s wheel cleaner is on sale for ~$80 bucks and when i applied the code it didn't reduce the price any further. how is meg super degreaser...its super cheap i'm willing to give it a try. I know with some chemicals you have to watch your dilution ratios.
It looks like it doesn't let you stack it. :shrug: It's not a coupon code for the daily special or anything though. I guess when it's on special it wont use coupon discounts.
