Optimum Rotary Backing Plates for our Microfiber System
Discussion in 'Car Detailing Product Discussion' started by Chris@Optimum, Jan 6, 2012.
  1. Chris@Optimum
    Hi everyone,
    For those of you who've been waiting for the complete system to debut, we're a little closer. Here are the Rotary backing plates that are now available:
    We left the hook and look off the edge to allow you to get a good grip on the backing o avoid tearing the pads when removing:
    Thanks for looking!
  2. Kaban
    Kaban Welcome to Detailing
    How much
  3. rwisejr
    rwisejr DB Forum Supporter
    Sweet Chris
  4. teak
    teak Birth of a Detailer
    That's a great idea to leave the Velcro off the edge of the pad.
  5. nyrep1
    nyrep1 Obsessive Detailer
    yes great idea i wonder why no one else has done this
  6. Misha
    Misha Nuba Guru
    Small is 3" ?
  7. Stokdgs
    Stokdgs Detail Master
    It looks like the smallest backing plate is 2/3/4" maybe, I cant see the tape measure that clearly.
    Dan F
  8. Kaban
    that would be perfect for 3 and 4 inch pads man.
  9. Stokdgs
    I went out and measured a couple of my Rotary backing plates just now, and they are in Diameter, 2=3/4" = 3" pads, and 3-3/4" = 4" pads.
    Chris, did Optimum develop these backing plates specifically for the Optimum Microfiber Discs on a Rotary ?
    Dan F
  10. dr.jay
    dr.jay Birth of a Detailer
    They look identical to my CG Evolve backing plates :shead:
  11. Kaban
    Are the CG backing plates available in different sizes? I only know of their 5" pad.
  12. dr.jay
  13. Chris@Optimum
    $14, $19, $21
    I agree and once you use it, you will love that feature.
    2.75", 4.75", 5.75"
  14. Chris@Optimum
    Yes, we worked with our supplier to tweak them: we wanted the hook and loop to mesh perfectly so that no pad damage would occur with frequent removal, we wanted the edge milled to assist removal, and the interface foam will make the MF pads much easier to control.
  15. Chris@Optimum
    You'll have to look a little closer. The 3" has about a 30deg angle where as the CG has about a 15deg...not that that matters, but they aren't the same. They do look similar though.
  16. Kaban
    Those are great prices!
    Can you use these with regular foam pads too? I don't see why not but you never know.
  17. Stokdgs
    Thanks Chris !
    It is really nice when a Supplier will actually give us the information we need in a timely manner or at all..
    Since all Detailers who do this for a living have to be most innovative, having the "nuts and bolts" info really helps us make our decisions easier.
    I see Optimum made Backing Plates for 3" 5" and 6" pads; are you going to make a 3-3/4" plate for 4" pads?
    Great looking Backing Plates and Microfiber; has anyone used the cutting microfiber and finishing microfiber with a Rotary, and can we see the results?
    Thanks again - Happy New Year !
    Dan F
  18. Chris@Optimum
    Yes, you can use them with foam, too! The velcro should match up sine with most major brands.
  19. Chris@Optimum
    Thank you for the compliment. I try to catch all the questions, but if i ever miss one you guys can PM or email me anytime.
    I have a single set of 4" pads, but I'm not sure they will make the first run of pads. But when we release the 4" pads, we should have a 3.75" plate as well.
  20. Kaban
    I've been surprised overall at how supportive Detailing Bliss is with all its members and vendors. It's very nice for a change.
