Optimum Power Clean Drying on Paint
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by mharris2007, Jun 24, 2011.
  1. mharris2007
    mharris2007 Two Bucket System Washer
    Hi,
    I'm going to be detailing my buddie's 997 porsche turbo that is black (not metallic). I have my paint correction/LSP plan down thanks to Ken and others.
    Anywho, he recently waxed his car so I'm going to need strip the LSP off. I tried just CG CWC in a foam cannon at "stripping strength" with no avail on my M3 when I polished it. The LSP was still there after claying as well. So......I was going to mix in some optimum power clean into the foam cannon to help with the pain stripping or use a dilution of OPC prior to foaming. The car is going to be washed outside and I know people let the foam "dwell" on the car for 5 minutes or whatever, but I was worried that it may stain or hurt the finish if it dried?
    I guess I'm trying to understand how to best strip LSP without stainging the paint (which happened to my dad's silver F150 when I sprayed OPC @ 3:1 on certain areas). I have a gilmore foam gun with CWC at LSP stripping strenght. If anyone has any suggestions that would be great, and what ratio's you use of CWC and OPC in the foam gun. Thanks so much.
    Matt
  2. bakchoi
    bakchoi Birth of a Detailer
    I think I read chris@optimum said to strip LSP you use powerclean straight up no dilution. Have to find that post again.
  3. mharris2007
    Really?? That would make me uber nervous. Especially if the sun is semi out while you're doing it. Let it dry?
  4. Kaban
    Kaban Welcome to Detailing
    You shouldn't be getting staining if you don't leave it on too long to dry or leave it out in the baking sun. Don't spray it on a hot panel either especially on a black or dark colored car. You shouldn't be letting any degreasing product dry anyways.
  5. Kaban
    NO! Do not let it dry lol. EVER.
  6. Kilo6_one
    I use 1:1 powerclean with half an oz of dawn and it rips pretty much everything right off the car. LOL
  7. Kaban
    Kilo, is here a reason only "DAWN" dishsoap is ever mentioned for stripping LSP? I've used other dishsoaps too with great success. Just wondering what makes Dawn so special.
  8. astro_ng
    astro_ng Jedi Nuba
    Dawn has always worked for me, with the clay bar nothing ever remains.
    Dawn is a detergent, used to strip all oils from your dishes!
  9. mharris2007
    Thanks for the help guys. I'll go 1:1 on the opc with some dawn in the foam gun and see what happens. If this doesn't work I'll resort to an ipa wipe down. Once you apply with the gun do u just start washing with your suds then rinse? Or do u let it dwell to the point of nearly drying?
  10. mrgolfrider
    If the wax is still there after your OPC foaming and claying on the friends car the polishing step in the detail will remove it for sure. If you are also worried about the OPC drying on the car try and get an early start before the sun is overhead in your area to reduce that happening. I usually get started on my details at about 7 A.M. so that I know the panels will be cool.
  11. Chris@Optimum
    It's the foam gun that is preventing stripping. Just spray OPC on the panel, let it dwell a bit , then bucket wash and rinse. Foam looks cool, but it's just for washing lubrication. The dilution with water and all the air makes the chemical LESS effective.
  12. Kilo6_one
    Dawn is a generic term really, Palmolive works good too. But I prefer Dawn because it save baby animals from oil spills so obviously its ok on a car.
  13. mharris2007
    We were going to get started about 8am as I'm making by friend help me and he wished to start at 8 am since we have all day. I preferred that as well because if I started at 7am I'd hit the wall by 2 or 3 pm.
    Oh crap! Really? What dilution on the opc do you use for spraying directly on the panel? I've heard 1:1, 3:1, or straight undiluted?
    Thanks so much.
  14. Kilo6_one
    I use 1:1 in a bug sprayer with 1oz of dawn.
  15. mharris2007
    Cool, thank so much.
