Optimum Coating Case
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by Rcrew, May 16, 2013.
  1. Rcrew
    Rcrew Wax on..Wax off
    Wanted to share my new setup for OPT Coating storage. Makes for more professional presentation to my customers. What do you guys think?
  2. Colinpd137
    Colinpd137 Any Rag Vehicle Washer
    Honestly I really like it. Does add professionalism to the presentation of OC, instead of a syringe in a bag lol.
    What did the case/foam cost you?
  3. Rcrew
    It's a Pelican case and didn't come cheap (foam included)
    Image is huge with customers, so it was worth it
  4. Cobrakai
    Cobrakai Virgin Detailer
    Not trying to be a jerk or anything, but I think the foam cuts should be uniform and cleaned up a bit. Great idea though
  5. Rcrew
    I appreciate the feedback. The foam is a pick & pull style, so it is pre-cut into little squares. It would be tough to cut them in smaller increments.
  6. RZJZA80
    RZJZA80 Two Bucket System Washer
    You can use an exacto knife and trim the foam as needed, we have dozens of them at my office,
  7. Kilo6_one
  8. Kilo6_one
    OR. get a foam block (non pick and pluck) and hot wire cut it. Google it....... its how pre cut foam is done.
    BTW, I have seen pelican cases run over by trucks and nothing happened other then it cracked. They are the only cases the DOD is contracted to use.
    If you can afford it, its Definatley the way to go.
