ONR wash media...
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by pektel, Dec 15, 2009.
  1. pektel
    pektel DB Forum Supporter
  2. blacK20
    blacK20 Birth of a Detailer
    I use a chenille mitt. I find the big thick pads hold too much water and I end up going through the bucket of onr in no time.
  3. BrendanS
    BrendanS Welcome to Detailing
    Proline Grout Sponge
  4. GDAL
    GDAL Guest
    I use the uber green mfs. They seem to work great.
    I want to try ONR with the uber sponge.
  5. pektel
    I've tried it with a sponge. Both proline and uber varieties. I don't like it at all. It doesn't have anything to lift the dirt away from the surface. At least, I didn't have any luck with it.
  6. GDAL
    GDAL Guest
    Try any fluffy mf and you should be ok. Just make sure you rinse them good and swap them often. I used 3-4 mfs per wash.
  7. pektel
    That's what I've been using. Shag Rags from Justin. I like them, just wondering if those wash pads would make it even safer.
  8. Denzil
    I'm still using my Zymol sponge but I used the Proline sponge and some plush MF's before.
  9. pektel
    What I really liked about the sponge was how easily it releases the dirt into the rinse bucket. What I didn't like was it seemed there was still contamination left on the paint surface, suspended and ready to be removed.
  10. Reflect
    I don't think those wash pads are that good.
  11. pektel
    I hadn't heard anything about them. Looks like I'll keep with the shag rags! Thanks for the input.
  12. Bunky
    Bunky Guest
    I think Adam's sells some similar wash pads but the ones in the Adam's video look much bigger.
  13. pektel
    To me it looks like a sheepskin mitt, but no place to insert your hand. Just a pad, so to speak. That's how I use sheepskin mitts anyways.
  14. agpatel
    agpatel OD On Detailing
    I use a Griots MF wash pad, the MF pads/mitt that looks like dread locks. Was looking at the SV poodle (or w/e they call it) pad but expensive to get.
  15. Bunky
    Bunky Guest
    I have used several.
    Next time, I am going to try a dreadlock style that inserted a wash sponge so it works better in the hand since I never inserted my hand in the mitt anyway.
  16. blackjz
    blackjz Jedi Nuba
    i use sheepskin for ONR wash, is that ok?
  17. Chris@Optimum
    I use ShagRags and I've been doing it a little different lately with great results! I use ONR in a NOMAD washer. Don't bother rinsing the media, just switch to a new one when both sides are dirty. Only use .5 gallon on a Nissan Altima including rinsing the wheels. The NOMAD can spray a very fine mist or a stream (fully adjustable). I just wet a panel (hose in one hand), wash with dampened mitt till clean (add more ONR if needed), then dry as usual. Sure I use more towels, but I have very thick pile shagrags and only use about 3-4 per car.
    Another bonus is that I can spray regular wheel cleaner on the rims with this technique because I can rinse. I have never marred with ONR the old way, but I think there is less chance this way because all the solution that hits the car is fresh.
    The nomad is self contained. You do not need a hose, it consists of a tank (3.5 gallons), an internal pump (provides about 40-60 psi), a power cord (lighter plug 12v), and a kink free hose (20ft with sprayer).
    I end up with less on the garage floor with this method and I use my jump start power pack to run it instead of pluging it into the car or the wall. I have stored the ONR in it when not in use with no noticeable decline in performance to the Nomad or the wash solution.
    To start remove the cap, attach the hose (without the sprayer) and aim into the tank, run for 20 sec to purge aur from the line, attach the sprayer and go to work.
  18. dsms
    dsms DB Forum Supporter
    nailed it ^^^
  19. Follmer
    Follmer Birth of a Detailer
    I feel dumb but ive been trying to figure out what onr stands for lol
  20. Chris@Optimum
    Optimum No Rinse Wash and Shine, Rinseless Wash
