Only 1 Menzerna ??
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by Rustbucket, Jul 11, 2008.
  1. Rustbucket
    Rustbucket Birth of a Detailer
    Ok, my Aunt is in the UK and could bring back only one bottle of Menzerna for me. (packing space an issue):sorry:
    If you had to just have one Menzerna polish what would it be? The kind of all in one swirl remover and make your paint shiney again polish.:shrug:
    I know I see the guys using 106FF a lot.
  2. Nica
    I'd say 85RD3.02 or I think the name is Super Intensive Polish...I think, I'm used to calling it by the number :shrug:
    Any who, you can't go wrong with this product. Usually delivers great results, some vehicles require two to three passes to get it just right though.
  3. MadOzodi
    MadOzodi Nuba Guru
    Nica's got it right as far as names go.
    PO85RD3.02 = PO83Q = SIP
    But I wouldn't be surprised if there are even more for the same product.
  4. Dave KG
    Dave KG Jedi Nuba
    The best all rounder of the group would be the PO85RD3.02, which you will find in the UK called Menzerna Intensive Polish... finishes down LSP ready, especially if you use the Zenith Point technique when polishing by rotary and also has the bite to remove anything from mild to moderate marring on most paints. The 106FF is very nice, but a bit weaker in cut so less of an allrounder.
    The best finishing polish is the PO85RD Final Finish, truly superb and IMHO no matched by any other on the market today - but it wont correct all that very much at all, so you loose out kin that sense.
    If I could only have 1, it would be PO85RD3.02 Intensive Polish. :)
  5. Calgarydetail
    my vote goes to 3.02
  6. detaildoc
    detaildoc Guest
    Definitely Super Intensive Polish
  7. slanguage
    ^ Iagree
  8. Dream Machines
    Dream Machines Jedi Nuba
    If I could only have 1 - it has to be 85RD Finishing polish
    As dave said, totally unmatched by any other abrasive polish for overall finish
    3.02 however would be my other choice
  9. Rustbucket
    Thanks so much guys.
    Ok, should have mine when she comes back next week. Trying to push for 1 liter but think 500ml will be all she can fit.
  10. trhland
    trhland Nuba Guru
    ive used 106ff and a lakecounrty white pad and have had great results!! removed those hairline micro swirls . the ones only seen in direct sun . lsp ready as well....
  11. Crossroaddetail
    Crossroaddetail Any Rag Vehicle Washer
    That's what I'd use, awesome all around polish.
  12. 911Fanatic
    Both of the polishes the guys are discussing, PO85RD and SIP are available in 250ml sizes in the UK. Get one of each!! Go to cleanyourcar.co.uk I believe and have a look.:thumb:
  13. Rustbucket
    Thanks guys.
    Yip, did order from Clean your car. Dealt with Tim. Very helpful guy and got the good sent out ASAP. Only problem with the 250ml bottle is that the 1 ltr is just so much cheaper then 2 X 250 ml bottles.:gasp:
    Well, cant wait to give the stuff a go. Still have some LC pads that will come from Phill too.
