Oil stains on leather?
Discussion in 'Interior Car Care' started by dsms, Jul 27, 2008.
  1. dsms
    dsms DB Forum Supporter
    A customer called me today regarding his wifes Mercedes stained leather. He said she spilled some kind of oil (maybe olive oil) on the rear seats and asked if I had something to get the stain out. Im sure the stain has been sitting for a long time already. Now I would think using a strong leather cleaner would do the trick but I feel it might not work to get the full stain out. Any tips on a thick oil based stain in leather? I have both LM strong cleaner and the Rapid S cleaner which should work well but it may not be enough.
  2. judyb
    judyb Any Rag Vehicle Washer
    This will depend on several factors, the type of leather is a key one. If the leather is at all absorbent (come across several recently) then the oil will have soaked into the leather and no amount of cleaning will get rid of it. If it has soaked into the leather then you will need to use a degreaser to remove the oil stain and this may (or may not) pull colour with it (again you won't know until you try) in which case you will need to know how to resolve this problem too.
    If the leather is a pigment coated one and the oil has been sitting on the surface then your cleaners should clean away the residues. If the oil has been sitting for a long time it may have left a grease mark which your cleaners will not remove. This may take stronger solvents to shift or it may need degreasing depending on the severity of the mark. If you use a degreaser you will be able to colour over the top when you have finished but you will not be able to recolour if there is any oil/grease present as the pigment will not adhere.
    Hope this makes sense and helps
  3. dsms
    Thank for the help, hopefully I will be able to treat the stain.
  4. togwt
    Sticky leather surface '- body oils (or sun-tan oil) mixed with road dirt from the a/c could be the cause or an oil-based product was used; use a LM's Leather Degreaser (check for colour fastness) this aerosol product is ideal for cleaning oily stains; it dissolves and removes oil and grease from leather surface. This cleaner can be applied for cleaning all types of leather.
    See article -Basic Automotive Leather Care - DetailingWiki
  5. gio
    gio Any Rag Vehicle Washer
    Do you have Goo Gone?
    I think this can solve the probs. Or try Meg's APC.
    hope can help.
