oil based wood stain
Discussion in 'Interior Car Care' started by pektel, May 11, 2010.
  1. pektel
    pektel DB Forum Supporter
    So, my mom's boyfriend just called me. Yesterday he had a can of minwax oil based stain leak onto the carpet. He is not sure of the maount that leaked. I am guessing 8-10 oz. He is not concerned with removing the discoloration, as the carpet is a dark color already. What he is concerned with is the strong smell that gives him a strong headache while driving. He asked what he could do. I said he would need a solvent, but I do not know the proper solvent to use, and if I should use my Bissell LGM or just towels.
    The can says to clean with mineral spirits or paint thinner, but I am not sure these are acceptable to use on interior carpet.
    Vehicle is a 2003 Ford Explorer.
    Thanks in advance!
  2. I would mop up as much as possible with some old thirts or terry towels then hit it with laquer thinner. The carpet is ruined at this point anyway so whats there to lose if the laquer thinner does stain the stain :giggle:
    I honestly do not beleive it will though. If it did you could also come back and redye that area once you have it cleaned and dry :cig:
  3. pektel
    I guess my biggest worry is a strong solvent destroying the carpet glue/backing.
  4. If worse comes to worse go to the salvage yard and find another 03 Explorer to gut, clean and install :drinking2:
  5. pektel
    lol, yeah I guess there's always that!
  6. richy
    Pete...I would think any solvent whether it be mineral spirits or whatever, if it's strong enough to remove the stain, it would also be strong enough to adversely affect the glue. You are trading one evil for another. Try what Flash suggests with the old shirts and mop up as much as possible (might be too late for that too) and then go at it with an increasing amount of aggressiveness with leaving the mineral spirits till the end. In other words, save the big gun till the end in case it does more harm than good. We'll all be interested in how it turns out...be sure to take :picture:and let us know!
  7. pektel
    I don't think I will be attacking this one. Right now I'm jut going to give him advice. If he needs help, I'll help him out for sure.
  8. bige441
    bige441 Any Rag Vehicle Washer
    Thinner in a car would smell horrible. I would def. use mineral spirits. If he has a proplem with how it smells now and you used thinner to clean. It would be like sticking your nose to a gallon thinner.
  9. Hostage1978
    Hostage1978 Guest
    Towels (blue shop paper towels) to pull the oil up out of the carpet. I would then scrub the hell out of the area with Dawn blue dish detergent or a citrus based degreaser to try to break up the oil. Next, I would let that area dry.
    Best of luck!
