Noisy Images
Discussion in 'Detailing Bliss Lounge' started by 911Fanatic, Aug 8, 2008.
  1. 911Fanatic
    Keep in mind that I know absolutely nothing about cameras. I only got one because you guys are picture whores!! I have a Fuji Finepix S700 and am very happy with the pics I get from it. My question is, how do I get away from noisy pics taken in low light? All my pics taken inside seem to be very grainy.:shead:
  2. brianja
    brianja Jedi Nuba
    can you put up an example?
    Are you using flash?
  3. Chris
    Chris Two Bucket System Washer
    Are you hand holding or on a tripod? In low light conditions hand holding gets pretty tricky as the time it takes to get a good shot makes camera shake a much bigger problem.
    Are you shooting in full auto? If so give aperture priority mode a shot. You just set the aperture where you want it depending on the depth of field you are looking for and the camera will take care of the rest.
  4. P1et
    Your camera is probably putting the ISO at full boost in low-light circumstances. That is resulting in very grainy pics.
  5. sneek
    sneek Nuba Guru
    those were my thoughts exactly.
  6. richy
    Mine too...I have a fuji s8000fd and I set it in p mode and set the iso as low as possible
  7. Nica
    :nod: P1et said it well, ISO plays a huge role in poor quality pictures.
  8. DetailAddict
    DetailAddict Two Bucket System Washer
    turn down the ISO and use flash... but flash usually sucks... you can also turn down the flash too. I usually take pics in ISO 200 with 1/16 flash if I need it. then use Photoshop to adjust exposure later. Take them in RAW of course... :)
  9. CGM_WRX
    CGM_WRX Virgin Detailer
    Also there is a good chance that your camera is underexposing the scene slightly. While high ISO is the main culprit for a noisy image, trying to recover shadow detail in post processing is also a big issue especialy in low light instances. Bump up your exposure by 1-2 stops higher than your camera recomends and you should get some better results. If your camera lets you review the histogram make sure you are getting as much information in the scene to the right of the histogram as possible without clipping the highlights. See this article on exposing to the right for more information.
    Expose Right
    Oh yeah, I am new here. lol
    Great forum, a detailers paradise with a good photography section as well. :thumb:
  10. zspectrum
    zspectrum Jedi Nuba
    lower iso take a longer exposure. Or add light.
  11. adriankeith
    adriankeith Birth of a Detailer
    there are a few programs out there that can help to a certain degree but if you try to use it too extensively your pictures can turn out flat or not as sharp as before.
    Off the top of my head I can only think of Noise Ninja. I will post the names of the others i've used with good --> great results.
  12. Misha
    Misha Nuba Guru
    higher ISO number = more noise, try using flash
  13. Scott's Mobile Detailing
    this isn't always true...a pic takin at 200 ISO that is under exposed ....is going to have more noise than a shot taken at 400 ISO that is properly exposed
    Alot of people are scared to crank up the ISO because of fear of noise...
    Shoot at a smaller aperture lowest shutter speed possible and dont be scared to use 1600 ISO...it will look alot better than an underexposed shot at 800 ISO
  14. Carn
    Carn Welcome to Detailing
    Tripod with lower ISO would be my first approach, but I am no expert ;)
