Nissan Altima - Deluxe Detail Package
Discussion in 'Show and Shine' started by JPerrydore, Apr 17, 2012.
  1. JPerrydore
    JPerrydore Birth of a Detailer
    I was referred to this customer by one of my regulars. She was looking to have the vehicle cleaned up (for a reasonable price) so she could sell it to her brother.
    The vehicle had not seen an exterior wash since it was purchased in 2007. The interior had be vacuumed and cleaned a few times.
    There were two areas of concern on the exterior that she wanted to see if I could correct. She had rubbed her garage walls a few times...the front bumper was bad, but the passenger side wasn't too bad and was able to get almost 100% correction on it. Both areas were hit with D300 and then GPS.
    Products Used:
    OPC 3:1 - For cleaning the hard surfaces in the interior and the door jambs
    Folex - For carpets
    303 Aerospace - to dress the interior
    Megs Window Cleaner
    DP Xtreme Foam - In two buckets and used in foam cannon
    Dawn - Mixed with DP Xtreme foam in foam cannon
    Iron- X - For wheels and paint decontamination
    Poorboys Bug Squash
    Speedy Surface Prep Towel
    Glide - Lube for the Speedy towel
    ONR - Diluted to clay lube strength
    Pinnacle poly clay - for the heavily contaminated sections
    D300
    Optimum GPS
    Blackfire Tire Gel
    Chemical Guys Stripper Scent
    Kleen Keyboard q-tip type things (can't recall the exact name off the top of my head). Use them for cleaning vents and hard to reach areas. Also have some for dressing.
    Equipment Used:
    Three 5 gallon buckets - 1 for wheels/tires and 2 for the normal wash
    Karcher 2000psi Pressure washer
    Foam lance
    Vapor Clean Gaia - steamer portion only
    Chenille wash mitt
    Various brushes - stiff brush for tires, wheel well brush, lug nut brush, raceglaze brushes for emblems, door jambs, etc, carpet brushes
    Many MFs
    Cobro application
    Porter Cable 7424
    Megs MF Cutting disk - used with D300
    LC White pads - 3 for the whole car
    Ridge 4 gallon shop vac
    Now onto the pics...
    As the car arrived
    Front Bumper area - notice that some areas were taken all the way to the plastic
    This is the other area on the passenger side - not nearly as bad and some of it was just rubber transfer
    All the door jambs were pretty dirty
    The interior wasn't really bad, just some stains in the carpet that had been there awhile. The drivers side was the worse due to she didn't have mats in the car for awhile...so there are tears and heavy staining in this area. She just asked me to do a quick cleaning on it. I ended up spending more time than expected here cause I kept saying to myself "I know I can get it better" lol.
    After the vehicle was washed (sorry no pics, it's hard to do pics when I"m on my own). The paint was sprayed with Iron-X and let to dwell about 5 minutes.
    And the afters...interior first
    I wasn't completely satisfied with the drivers area carpet...I think if I had spent a little more time on it I could have gotten it a little better. But overall a good improvement.
    And the exterior pics
    Passenger side where the scratches were - all came out except one or two deep ones.
    Front bumper - really cleaned up nicely but there were a lot more deeper scratches here that I did not get out.
    The customer was thrilled with my work and will be bringing me her new Audi A4 a few times a year to keep up with it.
    Thanks for reading!
  2. ACE2790
    ACE2790 Jedi Nuba
    Good job! I love working on daily drivers because those are the ones that I feel detailers get the most reward out of.
  3. amercour
    amercour Birth of a Detailer
    Huge improvement. Excellent work. I just hope she does not destroy her new A4.
  4. JPerrydore
    They are always the worst to deal with. But your right they do make for great turn arounds!
    Let's hope!
  5. P1et
    Some really nice work. A car any brother would be proud to drive!
  6. GDAL
    GDAL Super Moderator
    great turnaround on the Altima. How did you like your Speedy Prep Towel?
  7. 604_Snooze
    604_Snooze Obsessive Detailer
    Which pad did you use the GPS with?
  8. JPerrydore
    Love the speedy prep towel! It makes the claying process so much easier. And it works quicker. This was the 1st car I used it on and after breaking it in (or so I thought) on the windows I started on the hood. It ended up marring the paint a little bit since it wasn't broken in completely. Nothing the GPS couldn't fix though. I've used it several times since then and now that it's broken in, it doesn't mar anything. I still like to clay heavily contaminated areas, but for everything else this is a real time saver!
    LC White pads
  9. supercharged
    Great job!!!
