New Products! Power Seal Long lasting protection made easy for everyone, this machine sealant is designed for use by DA and is packed with synthetic polymer protection, heat activated technology means it not only bonds but grips to paintwork providing 6-12 months protection. Satin The first progressive finish tire gel, formulated to give a long lasting finishing whatever you chose, a natural sheen on 1st application, satin on 2nd coat and gloss on 3rd, giving you total control over the finish, we believe this could be a game changer. Temptation The latest addition to our hand made wax range, Temptation is 200ml of hand blended & poured Carnauba hard wax for under $40 aimed at those new to hard waxes temptation has been formulated for ease of use and speed of application. Glide Its been a while, but its finally here, the perfect partner to our popular fine Clay Bar, Glide is a ready to use clay lube, perfect for up sell or in kit form to accompany our clay bars. Tough Prep Tough coat just got a buddy, a fully synthetic pre cleanser that contains the same protection qualities as Tough Coat to create the perfect base for our sealants.
Great move on releasing a paint sealant! Layering that with any of your waxes should result in some pretty impressive durability stats.
Tough prep has the same level of cut as Rejuvenate. Tough Prep is the ideal base for Tough Coat and Power Seal
Tripple still is a fantastic product. It is ideal for one step clean ups, under the door handles, under hoods, door jambs, anywhere you want to apply by hand to really shine up the area it works.
Martin, would there be any benefit to applying tough coat over the new power seal? It seems like there's a good amount of solvents in TC, so I'm wondering if putting it over the power seal would just compromise it.
