Anti-Frost Concentrate Washer Fluid Anti-Frost is a concentrated windshield washer fluid with anti-freeze properties that excels in cleaning performance with a glare-free finish. Special formula protects against re-icing, quickly removes road grime, streaks, silicone, and other elements that can impair driving. Contains a pleasant citrus scent. Guaranteed not to damage paint, glass or rubber. Suitable for plastic headlight lenses. Developed for leading European automotive manufacturers so you can be sure you'll get exceptional results. Environmentally friendly formula is made from pure natural alcohol and is 100% biodegradable. Does not contain toxic methanol or ammonia found in common brands. Fresh citrus scent! Mixing Ratios: 1.5 parts Anti-Frost + 1 part water - 22°F 1 part Anti-Frost + 1 part water -15°F* 1 part Anti-Frost + 2 parts water 7°F * * dilution ratio for "Type A" areas in California only 33.8 fl oz / 1 liter Price: $9.00 ETA 2/3/10
Quick Update! - Our cargo finally arrived so Anti-Frost will be available within a week with dealers. - Note the change in temperature level performance. 1:1 mixture of Anti-Frost protects up to -15F NOT -5F and originally posted. Other temps updated too.
