Phil- Are you going to bring in the other new OPT products, I believe they are going to be released towards the end of the month. They are coming out with a new headlight coating, glass coating and class coating maintenance/cleaner product. These will be hot sellers for sure!!!
My understanding is that in the same way Opti-Coat bonds and becomes part of the clear coat, so their glass coating does with surfaces made from silica like glass. Hopefully it has some super slick properties too.
Opti-Glass Coating is designed to chemically bond to silica based surfaces to form a hydrophobic film that provides long term protection to glass and other silica based surfaces and to increase chip resistance, scratch and mar resistance, and protect from water staining. You can expect 1 year from the consumer version (windshield one year...other windows will last longer) and around 3 years for the pro version. Opti-Glass Clean & Protect concentrate is designed to clean and protect automotive glass with a simple application. The polymers will bond to glass surfaces and continue to add protection every time you use this product. Use it by itself or in combination with Opti-Glass Coating for maximum protection and hydrophobicity. Opti-Lens Coating is the most advanced pre-polymer resin for headlight protection. Once applied to the headlight or other hard surfaces, the resin will form covalent bonds with the substrate and crosslinks to form a permanent film. Opti-Lens coating contains high levels of UV blockers to prevent lenses from yellowing over time.
