New Car
Discussion in 'Detailers Domain' started by outlander, Feb 25, 2011.
  1. outlander
    outlander Virgin Detailer
    Please recommend how to wax a new Acura 2011 dark gray. Plan is as follows: 1 wash. 2 Then clay using Pinnacle Clay. 3 Paint Cleaner? maybe? 4.. Poorboys black Hole. 5 Natty's Blue. Please advise:shead:
  2. tdekany
    tdekany Wax on..Wax off
    either by hand or a machine. Is that what you are asking?
  3. M3ride.
    M3ride. Wax on..Wax off
    I would say apply both Black Hole and Natty's Blue by hand. Your stages are spot on. Black Hole already contains light cleaners in it so no need to use another cleaner before that. And I would say 2 coats of Natty's Blue an hour apart should be good enough.
  4. kyoshiro
    kyoshiro DB Forum Supporter
    I would advise a possible stronger paint cleaner (or even gogo polish) due to possible clay marring on honda soft paint/clearcoat, just a suggestion.
  5. outlander
  6. M3ride.
    Ya with hand application go with straight lines with both the glaze and wax. I've used this method and it has worked well for me. After you apply the Black Hole let it haze then wipe off. And then apply Natty's Blue and let it haze then wipe off. You could probley do the entire car with both instead of just panel by panel but that's up to you. They are both great products.
