Need the truth!!
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by Dust2Glory, Sep 16, 2008.
  1. Dust2Glory
    Dust2Glory Nuba Guru
    Is the new 1Z Pro-line High Gloss as good as SIP? Can anyone that has actually used the two confirm or deny this?
    If so I'm ditching the gallon of SIP and going with 1Z... I know that Scott's Mobile is bringing his sample on the 27th, but can anyone give insight now?
  2. slanguage
    Soon. I just ordered the 1Z Intensive to replace my SIP, which I am almost out of.
  3. eShine
    eShine Guest
    Only YOU can answer that question. You have to simply try the products and see what you like better.
  4. Denzil
    My 1Z is on the way... I believe I should be getting it this Thursday.
  5. eyezack87
    eyezack87 Guest
    Email 1Z for a sample. Thats what I did to get a sample so I can do my own comparison. I'm doing a test of them verses the Menz line and Prima line :)
    Shipping for me was $5 btw
  6. Brian N
    Brian N Jedi Nuba
    How are you going to compare it to SIP?:shead:
  7. eyezack87
    eyezack87 Guest
    ^^I borrow a small bit from you. Just enough to do a 1x1 square :)
  8. Brian N
    Brian N Jedi Nuba
    Alright but let me warn you I charge ten dollars an ounce. :applause2:
  9. eyezack87
    eyezack87 Guest
    Haha, considering that we pretty much finished your trunk with my stuff you shouldn't be charging me :pye:
    Either way, I hope it compares quite well. I feel like detailing something already other than my own cars :gidiup:
  10. Cooter
    lol just think. 32oz = $320 . Schwing!!!
  11. sal329
    sal329 Nuba Guru
    I am interested in the results.
  12. scheerspeed
    the answer is NO!
    i tried Hoch Glanz (high gloss polish) on a black M3 on a white CCS pad at 900 RPM. it cut as much as 106, but finished with some holograms... i wasn't very happy with it. what i did like is that it doesn't fill scratches at all.
  13. Scott's Mobile Detailing
    did u compare the two on the same paint?
