I purchased a foam cannon, like the one at pwmall.com, and I'm wanting just to connect it directly to my wand. I often see this being done BUT, the cannon has a 1/4 quick connector and my wand is a 3/8. What I'm needing is a maybe a 1/4 to a 3/8 quick connect which I haven't found at lowes or home depot. Any help is appreciated.
If it is the one on PW Mall, the quick connect can be unscrewed if need be, and you can purchase the appropriate connection from Autogeek by looking at their Foam Cannon page, on the bottom. You will need the brass male connector PLUS the appropriate connector for your brand of pressure washer. When those arrive, just unscrew the quick connect which came with your foam gun, screw in the brass connector, and then screw on the appropriate adapter for your pressure and you should be set. That's what I did for mine which I ordered on PWMall. Hope this helps.
I'll take a look. Thank you for the quick reply. While your here Richy, have you tried Zeps all purpose cleaner? It's green and usually right beside the citrus cleaner.
