1. christian900se
    Hey there, first of all happy thanks giving! Hope everyone had a great day.
    I have run into a problem that I cannot seem to fix no matter what I have tried: my mom must have driven through a literal puddle of some kind of wood stain or varnish because there are huge spatters of it all over the driver's side of our black RX400h. I have already tried:
    -IPA soaking
    -Optimum Power Clean
    -Clay (way too much for clay to deal with)
    -Gently picking off the spots and trails of this stuff (would need to polish afterwards due to slight scratches)
    What do you guys recommend I should try? I rarely run into something I have not been able to fix but this one has me well and truly stumped.
    Thanks!
  2. kyoshiro
    kyoshiro DB Forum Supporter
    the valu something Twin may work
  3. Danny
    Danny Nuba Guru
    Why not try wet sanding with 2500 or 3000 grit then follow it up by polishing it out. If you already tried claying, IPA, and APC and none of those worked. I say try the above unless you know of another gentler way of approaching it. Also pics would help out a lot.
  4. christian900se
    Let me snap a few pictures, I will post them to give you some perspective. Some of it is still soft while others are slightly hardened, however I do not think wetsanding would be the best plan of attack yet. My next step is to use some type of tar removal product like Tarminator or some comparable tar remover.
  5. GDAL
    GDAL Guest
    Krud Kutter or Tarminator
  6. detail addiction
    detail addiction DB Pro Supporter
    A good solvent might work.
  7. christian900se
  8. kyoshiro
    you'll need to polish out that panel anyways, i see swirlz
    it looks like glue actually
    try some adhesive remover with plastic blades
  9. christian900se
    Haha, I will admit I have not polished the car under the trim line for a little while (I can assure you the rest is near swirl free though!). I will grab a can of Tarminator or adhesive remover tomorrow and will post once I see if that helps.
    Thanks for the help everyone, I really appreciate it.
  10. POPPAJ
    POPPAJ DB Forum Supporter
    heat gun-plastic razor blade-polish-wax
  11. billyblooshoes
    Solvent or laquer thinner.
  12. Dannyk
    Dannyk Jedi Nuba
    Looks like varnish or pine tree sap. Not asking for you to sniff it per se, but does it have an oder? I second the solvent or lacquer thinner suggestion based upon appearance. Use the piece you have pictured and see what works to dissolve it.
  13. christian900se
    Sorry for the delay: Stoner's Tarminator had no effect whatsoever so I am going to Home Depot and getting some lacquer thinner I think. This stuff smells like straight up wood stain/varnish/lacquer and is ALL over the entire driver's side! This is the worse detailing event I have had to deal with so far! There is just so much of it.
  14. tfish1
    tfish1 Birth of a Detailer
    id say heat gun after soaked in goo gone orange and plastic razor blade
  15. Reflect
    +1 on that. As long as you are careful, neither will hurt your finish.
  16. Dannyk
    Dannyk Jedi Nuba
    One of the things i have been using to remove tough spots is Autosol metal polish. Ever try removing mold spores that exploded and seems like nothing wants to work on it, Autosol does.
    This is what i would be trying to use first, and then maybe try what has been recommended in this thread.
