Need help with foam cannon
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by jikim83, Mar 19, 2012.
  1. jikim83
    jikim83 Virgin Detailer
    I just got mtm foam cannon
    i tried to used it yesterday filled it up 2oz of cg honeydew
    and rest of water. The problem is when i spray it it squirt every direction
    from nozzle instead of wide spraying pattern
    let me know if anybody know how to fix this thanks
  2. JoeyV
    JoeyV Welcome to Detailing
    I don't think I have the same cannon as you, but in general, the tip/nozzle of it can be turned to change the spray. It will switch from a very wide spray(what you're getting now) to a straight stream. If it doesn't change, then it might be broken...or I'm just way too unfamiliar with that foam cannon and I'm completely wrong. In that case, just disregard my message :p
  3. mrd0t
    mrd0t Obsessive Detailer
    Just make adjustments to the Air Inflow knob and Nozzle Output adjuster.
  4. twist the nozzle my friend
