Hi. :worship2: Has anyone ever tried the WOWO method using the Natty's blue/red? It makes it as easy to use as, for example, the P21S and it leaves a nice finish. I'm a bit worried about durability. Do you recommend any other procedure? Whenever I let it haze, I find it a bit too hard to take off and it leaves some marks. Should I let it hazelonger? Thank you.
That's why P21S is a wowo product. I find using a low nap mf like Pakshak white edgeless towel to remove the wax and do not do a final buff works better. If you wipe of the wax and final buff IMO you are removing too much of the wax. By removing the wax without a final buff the wax will have time to cure.
I've been using Natty's Bluie now on a couple of cars as the LSP. However, I haven't tried the WOWO method. Have been using 2 coats with 12 hour cures between application. Has held up well on my daily driver.
used it a few times, and just did the swipe test to decide when it was time to buff off. I found it seemed to be ready pretty quickly anyway, maybe 3-4 mins on a warm day. (thats UK warm not hot US warm )
Never had a problem with blue, but I think I'll try the WOWO method with Red. Red's a bugger to get off some times.
