NanoSkin AutoScrub Foam Pad
Discussion in 'Car Detailing Product Discussion' started by NickBlaine, Dec 27, 2013.
  1. NickBlaine
    NickBlaine Any Rag Vehicle Washer
    What speed is everyone using when using the autoscrub foam pad on your polisher?
    I washed the car last week (haven't been able to do much in a few months with a slipping disk). The car felt like sandpaper, so I gave the new rupes a shot with the nanoskin. I got about halfway done with the car, and the pad went flying off. It had started ripping apart. Not sure what I was doing wrong- speed at 4.5, UWW as lube, constantly spraying. There was no heat, nothing grabby. Any ideas?
    Thanks
  2. porta
    porta Jedi Nuba
    To high speed. Just go for 1 and no pressure, just let the pad to the job.
  3. NickBlaine
    I was way off then... I always stayed around 4 or so, with no pressure. Guess I will be ordering another one and do it right. Thanks
  4. irsankao
    irsankao Virgin Detailer
    When you use nanoskin foam pad, a PC and speed setting 1. Do you do just 1 pass? or multiple pass like you use traditional clay?
  5. 99monguse
    99monguse Birth of a Detailer
    I have the nanoskin pad too...I believe the packaging it came with, explained how to use it, if you're not sure, YOUTUBE is your friend! I actually get better results with claying but that's me.
  6. Zonawildcats4
    Zonawildcats4 New Member
    Loved using the Nanoskin, made quick work of an otherwise long process. I used slow speed 1-2 when I did mine.
