My Blackberry pearl Volvo 940: Wetsanding..
Discussion in 'Show and Shine' started by virtual, Apr 21, 2008.
  1. virtual
    virtual DB Pro Supporter
    My car needed a makeover, haven't polished it since i bought it..
    The previous owner needs to learn a thing or two about washing techniques, found RDS all over the car when I started to inspect it.
    Tried to polish it using Optimum Compound and a wool pad, but the RDS were too deep.
    So I got inspired by the Meguiars wetsanding vids at youtube.
    My car is repainted, and there is a quite thick layer of paint.
    Products used:
    Wash:
    Tar remover
    Gritguard
    Chemical Guys Citrus Wash + Gloss
    Green Mf mitt
    Meguiars Waffle Weave
    Clay:
    Megs Quik Clay
    ONR mixed as lube
    Polishing/wetsanding:
    Optimum Compound - wool
    3m Perfect It III - Fast Cut Plus - wool
    Menzerna 106ff - white lc pad
    3m Imperial p2000
    Chemical Guys Synthetic QD for wetsanding lube
    Lsp:
    Chemical Guys Ez Creme Glaze
    Chemical Guys Jetseal 109
    The car:
    Started out very carefully wetsanding an old trunk lid
    I only had Optimum Compound available at this moment, so two passes was necessary..
    Here is after one pass:
    After 106ff:
    Only did one pass with Optimum Compound, so the result after 106ff were not 100% perfect.
    Over to my car! :)
    At this point I learned that wetsanding at the edges, is not a good idea!
    Was a PITA to remove those sanding marks, afraid to cut trough the paint..
    Area polished with Optimum Compound x2, and 106ff:
    After that result I felt way more confident, so I wetsanded the rest of the hood.
    Hood done:
    See the difference? Right panel is wetsanded, left I haven't done anything with..
    Time to do the rest of the car, so I bought 3m fast cut plus
    Tested on the left fender first..
    After fast cut plus and wool
    Time to do the rest of the car! :D
    Started polishing:
    After 106ff
    Time for an inspection in the sun:
    Found only small amounts of swirls, so took a few passes with 106ff:
    After ez creme glaze and jetseal:
    Outside:
    Still need to polish the side skirts, the upper part of the doors (by the windows) and the roof.
    Thanks for looking! :)
  2. pirex
    pirex DB Certified Dealer
    Very nice work Tommy! You know I like what you have done with your volvo. And it need balls to do something like that :D Can`t wait to see it finished!!
  3. cheeseenlo
    cheeseenlo Birth of a Detailer
    Wow, mad props to that job man. How long did all that take you? I have a couple areas on the car that i want to wetsand also. My neighbor thought it would be nice one day to scrap all the snow off my car with a grungy stiff brush.
  4. LanceM
    LanceM DB Forum Supporter
    wow. looks great. nice job on the wet sanding.
  5. Nica
    Wow that's a lot of wet sanding :thud:
    Nice turn around on that Volvo :applause:
    Thank you for sharing with us, very nice turn around :applause2:
  6. virtual
    Thanks Ketil, really appreciate it :D
    Thanks man :) Think I've spend atleast 20 hours so far, and there will be more :)
    The roof also needs alot of work, tons of orange peel :(
    hehe, stiff brush vs. paint is not a good match! :p
  7. sneek
    sneek Nuba Guru
    thats effing amazing!!!!
    That is super impressive!
    Great Work!!!!
  8. GBS
    GBS Wax on..Wax off
    Very nice job and a lot of work.
  9. Netspec
    Netspec Virgin Detailer
    You brought that Volvo's color back to life! Great job!:applause:
  10. Usjdmtuner
    Usjdmtuner Wax on..Wax off
    wow... you have courage... thanks for sharing and good job on wetsanding
  11. Showroom Shine
    Showroom Shine Birth of a Detailer
    Great Job! Give me the kick I need .
  12. virtual
    Thanks! It's a quite big car, so it's a lot of work..
    Man I want a smaller car :p
    Thanks a lot :)
    The best thing about this car, is when the sun flashes the paint, and it turns purple!
    It's nice to finally see the color swirl free :D
    Thanks man :)
    Thanks :) Just pick up the sanding papers, and start sanding! :D
  13. P1et
    First of all, big pre-Ford Volvo fan here! Great looking machine and that's a great color as well. It takes balls of steel to wetsand your entire car but it looks great now.
    Is it lowered a lot?
  14. PERFECTION
    PERFECTION Birth of a Detailer
    I have sanded a ton of cars and have never seen anyone just pic up paper and start sanding. Your the man.
  15. virtual
    Thanks! :D
    It's lowered about 10 cm I would guess, black and decker lowering kit :)
    Thanks man :)
    Had to try it, so why hesitate? :)
    Learned a lot after sanding my car, it's nice to know how sanding works.
  16. virtual
    Today was wash and wax day, used dp maxwax :)
    Plastics are not dressed on these pictures..
  17. Nica
    Man that Volvo is looking SWEET!!! :wicked:
    Thank you for sharing :peace:
  18. yukonon22
    yukonon22 Wax on..Wax off
    looks great
  19. Usjdmtuner
    wow.. love the color..ive been wetsanding like crazy also.. gotta love it..
  20. ChristR
    ChristR Birth of a Detailer
    Those pictures are proof that hard and proper work pays off!
