does menzerna make polish thats a mix of 106 and sip or 203? or is it ok to mix them to get benefit of both? i did mix them on pad couple times and results were pretty good, just not sure if it was my mind or it actualy worked, i honestly cant see difference in finish between 203 and 106
maybe its just me but sometimes 203 or sip doesnt remove very small scratches so trying to use 106 as helping mix since it has different abrasives that cut very fast and finish better, so maybe it will help with cutting and finish little better maybe it would be good as 1 step?
I added some po85rd to some 203 1:3 and it made for an unbelievably good one step polish that has a super long working time and nearly the same cut as 203 by itself, but with the benefit of finishing down to near 85rd levels. I don't see why you shouldn't try it out!
