are autospa microfiber products good? they feel so soft compared to the ones iv been using what are your 2 cents?
A couple of ‘non-scientific tests’ you could use to assimilate wither or not a towel will cause scratches, they are not at all scientific nor 100% accurate, they are only indicative of what the towel may do to your paint surface, but then which is preferable to scratch a CD or your paint surface? Ensure the towels have been washed before carrying out these ‘tests’. If the towel does scratch the CD’s surface that doesn’t necessarily mean that it will scratch the vehicles paint, a CD has a much softer surface than automobile paint so use caution, initially trying an inconspicuous area 1) CD Scratch Test- with a micro fibre cloth, using medium to heavy pressure rub the data surface of a CD. If no scratching is evident then it probably won’t scratch the vehicles paint surface, be aware that the bindings can also cause scratching. On first use of a towel use it on an inconspicuous area first. 2) Burn Test- to test a material for polyester content, light a thread, if it emits a black wisp of smoke and then shrivels up into a black hard ball, its polyester and will probably scratch your paint.
does 3m microfiber towels scratch? they are made of polyester. have anyone tried the 3m microfiber towel?
