Hi Chris / DB Im getting Micro marring using poli-seal with Uber green polishing pad and Uber blue finishing pad. My garage is 45 F. Im working on a 2011 brilliant black ( flat black ) Audi A4 . heres my process prime pad wipe excessive polish off the pad apply 3-4 dots of Poli-seal Working on 1 ft x 1 ft area Spread at speed 3 (2) fast passes Polish speed 5 (3) passes Finish speed 4 (2) passes I clean the pad or switch to new pad after every panel. am I doing anything wrong? or its cause of its a black car? could it be dust from my garage? I had no problems polishing with Flex 3403, Uber green Menz powerfinish and refine with Uber black 3M UF before. any help is appreciated Franki
i asumme speeds are for DA polisher? is it hard to wipe off? could it be marring from washing car or thats already been there and poliseal is not aggressive enough to take it off?
Yes its PCXP. its like butter when wiping off. No its not from washing my car, its like this *copied from Dave KG DA polishing article. I can only see it with Fenix TK11 LED light. but I have no picture with the LED. heres halogen shots
I'm lost, after all the cars I've hit with poly seal even adding polish II to the mix at a 70/30 mix I've never seen any marring and these customers I see alot doing maintenance washes on em. Not sure since your process sounds very good and close to mine other then the pads used.
It's Chris@Optimum...I can't log in but my old account works. I think your over working it and you may need a softer pad on some dark colors. Sent from my Verizon iPhone 4 using Tapatalk
That Brilliant Black paint is very soft. But you shouldnt be getting micro marring with the uber blue pad.
