The past two days have been spent by Bryan and I working on a Mercedes R Class, in black, which was looking a little more grey at the front than black... Big car this, definitely needed the two days as I did the exterior paint while Bryan worked on the interior on this one. Beginning with the exterior, after washing and claying it soon became obvious why the front of the car was looking more grey than black - hologramming, this car had been polished before: Tilting the Sun Gun can also highlight lighter hologramming more clearly: A short video here also shows the extent of the hologramming - the clouds moving around under the light source are the hologram effect: The hologramming was removed, after trialling various combos, using Menzerna PO85RD3.02 Intensive Polish with the Zenith Point Technique as follows: Spread at 600rpm, 1 pass Begin working at 1200rpm, 3 - 4 passes Work at 1500rpm, 10 passes until residue clear Refine at 1200rpm, 3 - 4 passes The results: On the video, we can see the region which is polishes which is free from holograms but the region unpolished still has the hologram effect: However, what was left on the finish was some RDS and with the paint thickness looking healthy, I decided to step up the correction to 3M Fast Cut Plus, applied using the "Cut & Dash" as follows: Spread at 600rpm, 1 pass Begin working at 1200rpm, 2 - 3 passes Work at 1500rpm, 3 - 4 passes until residue spread evenly Work at 1800 - 2000rpm, until defects removed (<10 passes) This was then refined with a dedicated (and IMHO best on the market) finishing polish: Menzerna PO85RD Final Finish applied using the Zenith Point Technique as follows: Spread at 600rpm, 1 pass Begin working at 900rpm, 2 - 3 passes until residue evenly spread Work at 1200rpm, 3 - 4 passes Work at 1500rpm, around 10 passes until residue clear Refine at 1200rpm, 3 - 4 passes Burnish at 900rpm, 2 - 3 passes The video below shows the state of the wing before cutting and reifning: And the results after: Before picture on the front wing: After: A little bit of wet sanding was required in isolated places to remove deeper scratches, like the following: Porter Cable was used, along with Abralon 4000 discs and a concentrated Shampoo Plus solution to lube the pad and the paint. Applied using speed 3 on the PC with no pressure and steady passes to remove the scratches, leaving a sanding haze: After cutting and refining to remove the sanding marks: The video below shows the bonnet after the correction and refining stage, wiped down with IPA ready to accept the sealent of choice: The bonnet after polishing, before any LSP: Moving away from the front and onto the doors, the hologramming was gone but there were general swirls: Trialling combos again where the paint condition had clearly changed, I still settled on the Fast Cut Plus followed by Final Finish as although the marring did not look bad, it was quite deep in places and coupled to hard paint I felt this warranted the cutting compound method. After cutting and refining: The odd dull spot was found around the car: Looked like T-Cut not being properly worked... This easily removed using the above technique though: One region on the car which seemed to have bad marring was below the styling lines on the doors: Two hits of Fast Cut required here to get good correction, this is the result before refining: After refining: More post correction shots around the car: The LSP of choice for this car was Duragloss Track Claw. First of all, Duragloss 601 Polish Bondaing agent was applied to the car and the residue just left. Track Claw was then applied straight over the top, left about five or ten minutes and the residue was then removed with ease. The results in the garage after LSP: While I worked away on the exterior paint, Bryan worked away on the interior: hoovering, extractor used on carpets and mats, leather cleaned and protected with Croftgate products, plastics treated with Poorboys Natural Look, glass with Meguiars Natural Look. Some pics of Bryan at work: Finished results on the interior: Bryan also tidied up the engine bay with some APC and then All Season Dressing: The chrome surrounds were polished by hand using Briliant #3 Premium Metal Polish: 50/50: left untreated, right treated: And to finish off, the wheels were waxed with Poorboys Wheel Wax, tyres dressed with Meguiars Hot Shine, glass outside cleaned with Meguiars Glass Cleaner Concentrate and the exhaust tips treated with wirewool, then Brilian #1 Metal Restorer. The end results, the car sitting waiting for the owner to pick it up: Glossy, deep reflection anyone?: Alas, the rain came on when the owner arrived, but at least this gave him the opportunity to see how quickly the water flew off the paint with the Track Claw on it! Final finished pictures: And some beading shots... A look now worthy of the three pointed star:
Well done there Dave and Bryan, I really like the amount of videos you posted :worship2: The vehicle looks great, very nice turn around...boy that vehicle was in poor shape but you guys did a great job at bringing it back to life, well done :applause: Thank you for sharing eace:
