its to remove any polish residue, etc so no you cant use it as a QD, you can use it as an IPA wipedown it will probably remove LSP yes.
Don't use it as a QD, it's for removing polish residue. It works okay with the Menzerna polishes, but don't like using it with anything else. An isopropyl alcohol solution is a better option imo, it's much easier to work with and it removes more polishing oils from the surface. Kind regards, Ebbe
