Menzerna question
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by Jadewall, Dec 30, 2010.
  1. Jadewall
    Jadewall Virgin Detailer
    Hello all
    I have a quick Menzerna question. Currently the two polishes I use are Power Finish and PO85RD. So my question is if I am looking for the next step up in aggressiveness what Menzerna polish should I be looking at? My car is a 2008 Subaru Forester XT and I here Subaru paint is on the softer side. Any recommendations would be a great help.
    Ryan
  2. P1et
    Get some SIP...
  3. Jadewall
    Awesome thank you. Can you confirm that Subaru paint is on the softer side by any chance?
    Ryan
  4. porta
    porta Jedi Nuba
    I would step up to a wool pad instead of using a more aggresive polish, something like Lake country foamed wool.
  5. CG6Lemon
    CG6Lemon New Member
    menz sip is the most aggressive polish they offer. after that would be menz 203 which you already have. then menz 106 and menz 85
  6. 911Fanatic
    Before going to a more aggressive polish, what machine and pads are you using? What exactly are you trying to accomplish?
  7. agpatel
    agpatel OD On Detailing
    PowerFinish and SIP have pretty much the same cut, the next polish up for menzerana is powerGloss compound which is a pretty heavy cut....i would say use wool with powerfinish if you are using a rotary or get some megs m105 which you can vary the cut a great deal.
    2x what Ken said...what are your tools.
  8. billy
    billy Obsessive Detailer
    +1
    Before buying something else i would try LC wool foamed pad
    just my :2cents:
  9. ryanb
    ryanb Virgin Detailer
    I find SIP to have less cut then Powerfinish. I would alter your pad first. Powergloss is pretty aggresive.
  10. Viny Detailer
    Viny Detailer Any Rag Vehicle Washer
    It would be good to post some photos for a better analysis. Without seeing it's hard to leave but a humble opinion.
    Luke ccs Kompressor or white and green with PF and SF achieves good results without damaging the paint ..
    PS. Personal opinion ...
  11. BoostedMk6
    BoostedMk6 Jedi Nuba
    This.
  12. Kilo6_one
  13. Chas
    Chas DB Forum Supporter
    Subaru is notorious for sticky paint at least when it comes to STI's not sure about a Forester.
  14. Kilo6_one
    Honestly Ive had to do some work on mine several times and never really found it to be all that bad. but i take it slow and work my way up. BUT, if you can work STI paint, you anything else should seem easier right LOL
  15. 911Fanatic
    Are you using a rotary or DA?
  16. Kilo6_one
    DA, i have had to correct a fender and my hood...... seems my dog wanted to jump up on it. I used powergloss with a green uber, which did not do much other then some minor removal. Then went to a orange uber and power finnish and it worked perfect, finnished it up with a few passes of final finnish / uber green and PL and you cant even see it. scratches were about 8 inches long on the hood and 5 inches on the fender.
    Is there a difference in STI paint between a DA and Rotary? i know some of the people who have used rotary's have had issues with it heating up the finnish making it real soft.
  17. Jadewall
    Currently Im using a PC with Uber green pad and power finish on the roof of my forester which is where the problem seems to be. For some reason there are some bad hard water spots that I cant seem to get rid of. I steeped it up to Power Finish with a Uber orange bad with no luck. I do have a Makita rotary but im not to the point where I feel comfortable using it on not a scrap panel. Sorry for the delay in getting back.
    Ryan
  18. Kilo6_one
    have you tried a water spot remover or it that bad? Ive had not issues using PF on waterspots. do you have any pics to post?
  19. Jadewall
    Im gonna run and take a pic right now Ill have it up in a few min.
    Ryan
